ᐅ Kitchen Photos Thread – Show Us Your Kitchens!
Created on: 16 Aug 2018 10:03
DieScholz´ens
Bought a house, estimated the renovation budget plus 10-15% for inevitable extras, and we set aside 5000 EUR for the kitchen!!!!
That’s how it started... at first, I was in a bit of shock, but we still had time. First step: remove all the walls for a new layout—I need space...
Let’s start with the (according to the agent) move-in ready property. The small kitchen, just under 8 square meters (about 86 square feet), had its 1970s pass-through removed. The wall including the kitchen door is gone! The wall next to the cellar stairs is gone too! Actually, the entire slanted wall, nearly 7 meters (23 feet) high, removed completely...
The window had to go as well since we needed a different working height than the standard 90 cm (35 inches). New screed installed, we switched to underfloor heating, all electrical wiring and water pipes are new.
After almost six months, the realization slowly sank in: the kitchen budget will not exceed 5000 EUR, so we had to look for a used kitchen... something special, but very cheap.
The search criteria: within a 100 km (62 miles) radius, up to 1000 EUR, because I still want new appliances.
Open living area with modern white kitchen, bright flooring and lots of light
Kitchen area with red tiled backsplash, white base cabinets and window
Bright, empty living room with white walls, laminate flooring and built-in shelf.
Bathroom under construction with floor tiles, red wall tile and sanitary connections
Kitchen shell with tiled floor, building materials and open ceiling during renovation
Construction site inside house with bare walls, cables and construction waste.
Child in winter jacket looking at unfinished interior with exposed walls and construction work.
Two workers renovating interior; exposed walls, tools and cable reels visible.
Interior finishing and remodeling: construction work in renovated space with open installations.
Costruttrice
7 Jul 2021 22:30
Chris2511 schrieb:
In the end, it’s you who decides what you want or need, not the kitchen showroom..
Of course, I’m the one who decides! I was just considered a total oddball, so I was simply curious.
In my current kitchen, I first had a steam oven; after it broke, I had a combined oven with microwave, pyrolysis cleaning, and steam boost; and now I want both because each has its advantages.
What you actually need is a different matter 😉 …
motorradsilke
8 Jul 2021 08:20
Do many people really do that? I think the thread just gives that impression – after all, it’s a kitchen thread :p
If you look at this forum, you’ll often see that people say you need to budget 15,000 to 20,000 euros (about $16,500 to $22,000) for a kitchen, so it does create that impression. But I’ve often wondered myself why such huge amounts are spent on kitchens and why expectations are so high. In our case, it’s because we don’t really enjoy cooking and therefore don’t spend much time in the kitchen.
guckuck2
8 Jul 2021 08:59
Well, you also have to consider where the price actually comes from. We also spent around €15,000-20,000. The cost is roughly divided into thirds for furniture, appliances, and countertop. Each of these categories has its own cost drivers.
Furniture
Mainly determined by size and front materials. A 10m (33 feet) lacquered surface costs more than 5m (16 feet) with foil covering.
Appliances
The number of appliances increases (steam oven, second oven), and prices for ventilation systems (downdraft, Berbel, Gutmann) have been driven up by the island kitchen trend. There’s a huge price difference between brands like Amica and Gaggenau. If you go for the “classic” four appliances in the mid-range (Bosch/Siemens/Neff), spending around €2,500 on appliances is easily achievable.
Countertop
Laminate countertops are considered standard and can sometimes be found for under €100 per meter (3 feet). Natural stone or composite, which used to dominate, is already about three times as expensive. Ceramic and Dekton are in the high triple digits per meter range.
I find the main cost drivers are easy to identify. For example, if you can do without the oversized, flush-mounted ceramic downdraft cooktop, you can quickly get under €10,000.
But as is often the case, forums, building blogs, and social media show that these are all must-haves.
chand1986
8 Jul 2021 09:32
@guckuck2
Good post.
In our home, the kitchen is used a lot; it’s a workspace. Efficiency comes from good planning and layout, not from the price.
We probably spend an extra third just on aesthetics because we can and want to. None of it is necessary to achieve the desired functionality.
But a certain level of aesthetics definitely contributes to a better feeling in a room where so much time is spent.
And between us: even as a student, I cooked complex meals on just two burners and got the results I wanted. In that sense, you spend a lot of money for more comfortable work, not for better outcomes.
hausnrplus258 Jul 2021 12:29
In my opinion, the kitchen and bathrooms rightly have a higher priority since they are usually kept for decades, unlike non-fixed furniture. Quite simple.
Bertram100
8 Jul 2021 13:16
Unfortunately, the times when people kept their furniture and kitchens for 25 years are almost gone. I hope it will return to that. Often, the products do not last that long. The advantage of constant upgrading is that I was able to buy almost all kitchen appliances (range hood, refrigerator, faucet, oven) secondhand.
