Aloadihoa11 Oct 2015 00:24We are currently in discussions with construction companies regarding the planned new build of a KfW 70 house. Construction is scheduled to start in summer 2016. We are still in the (free) design phase offered by turnkey providers. We want the KfW 70 standard not because of the loan, but simply to have a verifiable quality standard for the house (which is certainly advantageous for resale).
Planned features: solid construction, Liaplan Ultra 08, gas heating + solar thermal system, controlled residential ventilation with heat recovery, triple glazing.
One builder is pushing to submit the building permit/planning permission this year, arguing that it will be more expensive otherwise. I thought that a "KfW 70 house" before and after January 1, 2016, is essentially the same house, only that after that date it no longer qualifies for a favorable loan, which doesn’t matter to me.
Is there any advantage for me to submit the building permit/planning permission this year? I actually still have plenty of time for detailed planning and submitting the application now would create a lot of pressure, as it would mean committing fairly early to many details about the house. In addition, I would have to make a final decision on the construction company this year.
What are your thoughts on this?
Bauexperte11 Oct 2015 11:43Hello,
You have already provided the answer yourself as to why it is advisable to submit the building permit / planning permission application this year; you can still apply for funding under KfW 70 until 03/31/16 (March 31, 2016) with KfW.
The calculated efficiency values of a gas heating system deteriorate compared to renewable energies; for example, air-to-water heat pumps achieve "better" values. Therefore, with the equipment/technology mentioned above – currently KfW 70 corresponds to the Energy Saving Ordinance reference house as of 01/01/16 (January 1, 2016) – from January on you will not even meet the Energy Saving Ordinance value.
Why? There are also independent architects, aren’t there? Or is your focus primarily on a "free" design phase? Let me tell you, the "all-in-one solution" does not exist for you either.
Regards, Bauexperte
Aloadihoa schrieb:
Planned technology: solid construction house, Liaplan Ultra 08, gas heating + solar thermal system, controlled ventilation with heat recovery, triple glazing.
Aloadihoa schrieb:
And in addition, I would already have to make a final decision on a construction company this year.
Regards, Bauexperte
Aloadihoa11 Oct 2015 16:33I wasn’t really interested in any funding.
What do you mean by not even meeting the Energy Saving Ordinance standard? Which Energy Saving Ordinance standard? Because of the gas heating?
So, again: If I want to build to KFW70 according to the old Energy Saving Ordinance, then under the new Energy Saving Ordinance I only have the "reference house." As long as I don’t want to apply for funding, that would be fine, right? Only if I want to get funding, would I need to meet at least KFW70 under the new Energy Saving Ordinance (probably mandatory to install a heat pump), right?
Bauexperte11 Oct 2015 19:33Aloadihoa schrieb:
What do you mean by not even meeting the energy saving ordinance value? Which energy saving ordinance value? Because of the gas heating?Sorry – it should correctly be "energy saving ordinance standard."Aloadihoa schrieb:
So again: If I want to build to KfW70 standard according to the old energy saving ordinance, under the new energy saving ordinance I only have the "reference house."I have attached a PDF from the KfW Regional Conference 2014 here; this should make it clearer for you.Source: KfW Regional Conference 18.03.2014
Best regards, Bauexperte
