ᐅ KfW55 with 36 cm brick wall – feasible or not?
Created on: 11 Jul 2016 15:24
bluminger
Hello.
We are planning a single-family house together with an architect, aiming for KfW55 standard. According to the architect, using 36.5 cm (14.4 inches) bricks should not be a problem. With these dimensions, everything is now also approved for the building permit / planning permission.
The structural engineer is now skeptical, and the energy consultant said this wouldn’t be possible at all.
So basically the question is: Has anyone successfully done this before?
Also to be installed: air-to-water heat pump, controlled ventilation with heat recovery.
Thank you.
tabtab17 Jul 2016 12:20
That does not matter. T8 / T9 insulation, whether filled or unfilled, always has the same U-value. Only the sound insulation value changes.
bluminger30 Jul 2016 15:16
It will now also be possible for us with KfW55 and 36cm (14 inch) masonry walls.
Ground floor and attic walls require a thermal conductivity of λ=0.07 – likely filled brick or aerated concrete.
Window U-value 0.9.
Roof insulation must be a total of 32cm (13 inches).
MoeGT
18 Aug 2016 17:40
What do you think, is it possible to achieve KfW55 standard with a gas heating system just by adding insulation and installing a controlled ventilation system?
Goldi09111
18 Aug 2016 20:41
I don't think so, and the additional investment will not be proportional to the "better" conditions, at least with the current interest rates.
Climbee18 Aug 2016 21:30
I was told that the KfW55 standard can only be achieved using renewable energy sources. If you use gas, you are automatically disqualified.
My information.
Goldi09111
18 Aug 2016 21:42
Yes, the "nonsensical" panels on the roof are necessary.
