ᐅ KfW55 compared to KfW70
Created on: 19 Jun 2015 21:11
daytona
daytona
19 Jun 2015 21:11
I noticed that there will be changes to the KfW70 subsidy starting next year. Is it worth considering going for KfW55 instead? Is it possible to roughly estimate how much more expensive the construction measures for a KfW55 house are?
Regards
Payday
19 Jun 2015 21:37
As far as I understand from the construction company, KfW70 will become the standard starting next year. To qualify for proper funding, you will need KfW55. There might also be renaming of the programs, but I’m not really informed about that. There is a thread here discussing the changes in KfW funding.
Currently, the price difference between KfW70 and KfW55 varies depending on the provider (and the work required), but roughly speaking, it is around €6,000–10,000 (about $6,500–11,000).
V
vst85
15 Aug 2015 06:42
if your house is designed to KfW 70 standards, for example, a ventilation system (a decentralized one is more cost-effective) is enough to reach KfW 55.
This way, you can benefit from even better interest rates and a special repayment amount of 2500 € (euros) from KfW.
Best regards.
Legurit
15 Aug 2015 08:20
There are also providers who typically build to the KFW55 standard... it really depends on the provider.
Predicting the actual material costs is very difficult (especially since—as mentioned—there are many ways to achieve the same result)... and! in the end, it is not necessarily just additional costs, but also additional benefits.
Bauexperte
15 Aug 2015 10:11
vst85 schrieb:
If your house is designed to KfW 70 standards, for example, a ventilation system (decentralized, more cost-effective) is enough to achieve KfW 55.
That is a bold statement, which in most cases does not apply to solid construction houses!
Regards, Bauexperte
V
vst85
24 Aug 2015 22:23
Bauexperte schrieb:
That is a bold statement, which in most cases does not apply to solid construction!
Best regards, Bauexperte
Hello Bauexperte,
In my case, it is definitely like that. I also believe I have read in the forum that you achieve KfW 55 instead of 70 through technology rather than just adding more insulation.
Why do you think that this usually is not the case?
Regards.
