ᐅ KfW 55 – Ventilation System: Yes or No? – Experiences
Created on: 19 May 2020 13:29
exto1791
We are currently starting to deal with the technical aspects of our single-family home.
I haven’t found a thread discussing whether a ventilation system generally makes sense or not. So here is a general discussion thread on the topic:
At first, we looked into various timber frame construction providers, which made us quite sensitive in this area. Naturally, a ventilation system is quite important due to the tighter building envelope, which I can completely understand. However, everything is also marketed accordingly...
Since we have now decided to go with a regional solid construction company, completely different questions arise:
I currently have a detailed offer from a solid construction company:
- $10,000 additional cost for thermal insulation measures
- $13,000 additional cost for a central ventilation system or $9,000 additional cost for a decentralized ventilation system
--> So the repayment subsidy of $18,000 is of little use to me; on the contrary, I am even paying extra for this (of course, I get a “better” house in return).
Key Data:
- Single-family home city villa, 150m² (1,615 ft²) with basement
- Air-to-water heat pump
- Building material: brick
The questions I am now asking myself:
1. Is a ventilation system even necessary to achieve KfW 55 standard?
2. If yes, would it maybe make more sense to go for KfW 70 and forget about the subsidy?
3. Is a ventilation system really that great? There are many reports about noise, high maintenance, etc.
4. If yes, in our building project would a decentralized or central system be better? I have read a lot of positive things about decentralized systems, so central ones might not be an option? Is that correct or not?
5. Is it even possible to reach KfW 55 standard otherwise? Do you really have to ventilate every 2 hours? Are there any experiences?
6. Is the additional $10,000 cost for KfW 55 without a ventilation system justified? Are the prices for the ventilation systems justified?
I know this is an endless debate and there are clearly two opinions here. However, we find it really difficult to make a decision. Maybe a few discussions and information here will help us make up our minds.
FoxMulder24
30 Nov 2020 18:56
parcus schrieb:
Without a ventilation system, compliance with the Building Energy Act (Energy Saving Ordinance) is not permitted at higher energy efficiency standards. This also applies to the KfW, which uses the Energy Saving Ordinance or, more recently, the Building Energy Act as a basis. First of all, you need the space, which involves costs (fire protection aside), and then the ducts must be maintained. The energy consumption can be up to 15 times higher due to system losses. The heat exchanger efficiency in all good units is now well above the standard values.
The disadvantage of decentralized units is that they are visible on the façade.
Really, is that the case? Strange that KfW approved a KfW55 house without a ventilation system for me. I must have been lucky.
30 Nov 2020 20:29
FoxMulder24 schrieb:
Really, it’s there
No! There are no cables, only pipes, which do not require maintenance.
Space requirement: can be installed under the ceiling.
You mentioned the rest yourself.
Snowy36
1 Dec 2020 13:01
I’m constantly adjusting my mechanical ventilation system via the app—why wouldn’t I? That’s what it’s there for...
If I feel the need for better air quality: I manually set it to level 2. If I feel a draft on the sofa today: set it to absent mode.
I love this device...
Lumpi_LE
1 Dec 2020 15:15
Snowy36 schrieb:
Feeling the need for better air: manually set to level 2, I feel a draft on the sofa today: set to absent mode
I love this thing ...
In my opinion, if there is a need for better air or you feel a draft, the system is incorrectly adjusted and/or installed.
parcus
1 Dec 2020 15:24
@FoxMulder24
Or your energy consultant was asleep,...
Mycraft1 Dec 2020 15:25
Snowy36 schrieb:
I’m constantly adjusting my mechanical ventilation system via the app—why wouldn’t you? That’s what it’s there for...
Hmm, I agree with Lumpi: if you have to keep adjusting something all the time, either the system isn’t working properly or you just enjoy fiddling with apps. I can control not only the mechanical ventilation system but the entire house online, though I rarely do. Everything runs automatically, including the mechanical ventilation, which regulates itself.
