ᐅ KfW 55 – Ventilation System: Yes or No? – Experiences
Created on: 19 May 2020 13:29
exto1791
We are currently starting to deal with the technical aspects of our single-family home.
I haven’t found a thread discussing whether a ventilation system generally makes sense or not. So here is a general discussion thread on the topic:
At first, we looked into various timber frame construction providers, which made us quite sensitive in this area. Naturally, a ventilation system is quite important due to the tighter building envelope, which I can completely understand. However, everything is also marketed accordingly...
Since we have now decided to go with a regional solid construction company, completely different questions arise:
I currently have a detailed offer from a solid construction company:
- $10,000 additional cost for thermal insulation measures
- $13,000 additional cost for a central ventilation system or $9,000 additional cost for a decentralized ventilation system
--> So the repayment subsidy of $18,000 is of little use to me; on the contrary, I am even paying extra for this (of course, I get a “better” house in return).
Key Data:
- Single-family home city villa, 150m² (1,615 ft²) with basement
- Air-to-water heat pump
- Building material: brick
The questions I am now asking myself:
1. Is a ventilation system even necessary to achieve KfW 55 standard?
2. If yes, would it maybe make more sense to go for KfW 70 and forget about the subsidy?
3. Is a ventilation system really that great? There are many reports about noise, high maintenance, etc.
4. If yes, in our building project would a decentralized or central system be better? I have read a lot of positive things about decentralized systems, so central ones might not be an option? Is that correct or not?
5. Is it even possible to reach KfW 55 standard otherwise? Do you really have to ventilate every 2 hours? Are there any experiences?
6. Is the additional $10,000 cost for KfW 55 without a ventilation system justified? Are the prices for the ventilation systems justified?
I know this is an endless debate and there are clearly two opinions here. However, we find it really difficult to make a decision. Maybe a few discussions and information here will help us make up our minds.
Strahleman
29 Jun 2020 17:45
Abzug86 schrieb:
I’m starting to feel like I live in the Dummsdorf area when it comes to this topic.
Does it have to be a Helios ventilation system? Or are you allowed to choose alternatives? If so, I would look for Zehner installers, for example. Around Nuremberg, it seems like there is only one installer who really knows their way around heat pumps, BAFA subsidies, and proper heating load calculations.
Abzug86
30 Jun 2020 09:53
@Strahleman
I don’t really mind what kind of system it is, as long as it’s a good one. Could you tell me the installer from Nuremberg? Unfortunately, I’m not able to send private messages yet. Thanks!
Strahleman
30 Jun 2020 10:34
Abzug86 schrieb:
Can you tell me the installer from Nuremberg?
It is BL Klima from Nuremberg (just Google it, it should be the first search result). My contact person even actively pointed out that controlled residential ventilation can be subsidized if it is connected to the heat pump. This update had only been included in the information sheet for a few days.
Abzug86
30 Jun 2020 10:48
Thank you. I just called them, and they don’t do it. It’s either a heat pump with a ventilation system or nothing at all. The heat pump is already contractually fixed through my general contractor....
Tolentino30 Jun 2020 11:00
Maybe you can remove them? However, you will probably need to have the entire heating trade removed.
Without connections, it will be difficult to cover the cost of the alternative heating and climate technician with the credit. You will need to consider whether the subsidy is worth the additional effort and separate warranty. Part of the cost will likely be lost due to the general contractor's margin, which they will not credit to you.
Abzug86
30 Jun 2020 14:26
Unfortunately not. I set a fixed price including a discount, but only if I let the general contractor handle practically everything (at least everything they offer).
