ᐅ KALLAX – What Alternatives Are There to IKEA Inserts?
Created on: 9 May 2022 18:07
Bayram34
Bayram34
9 May 2022 18:07
Hello everyone, I am currently looking into storage furniture, specifically the KALLAX shelving system from IKEA. I find KALLAX interesting due to its modularity and value for money, but I am curious whether there are alternative uses or alternative products on the market that could be considered comparable or better options.
I am particularly interested in robust, flexible, and cost-effective alternatives—preferably with a different design approach or higher-quality materials. It would be helpful to know specifically which inserts or modular systems you are familiar with as alternatives to the IKEA KALLAX, that perform well in everyday use or even offer particular advantages over KALLAX.
What experiences have you had with these, and which manufacturers or products would you recommend? Thank you in advance!
Giagau
9 May 2022 18:45
That is a very good question, especially when it comes to KALLAX – it is often the first choice for flexible storage solutions.
As an alternative, I recommend taking a look at the modular system from USM Haller. Although it is in a higher price range, it stands out with extremely durable materials and a clear, modern design.
The advantage is that you can use the modules for both the living room and the office, offering much more flexibility in individual customization.
Another suggestion is the String system, which serves a different purpose but is also well suited for similar requirements.
For practical options with dimensions similar to KALLAX, you might also want to ask local carpenters about custom-made solutions, which often impress with even better material quality.
tinau
9 May 2022 19:11
If you are looking for storage systems similar to KALLAX, check out the "Expedit" at IKEA – it is still partially available and very similar to KALLAX.
Outside of IKEA, the modular shelving system from Modulor (a German brand) is an option.
Durable and similarly priced, but somewhat less flexible in design.
GALEO4
10 May 2022 08:30
Bayram34 schrieb:
I find the KALLAX interesting because of its modularity and value for money
But that is precisely the catch. KALLAX has established itself mainly due to its low price and simple construction.
My hypothesis: If you really value quality and versatile use, you inevitably have to invest more. Everything that is offered as a direct alternative to KALLAX on the market is usually either cheaper to produce or it is a niche product with a special design.
Would you question KALLAX because, for example, the material thickness is an issue for you? Or are you really looking for a completely different design approach?
PLOMA
10 May 2022 09:54
Regarding your question:
There are some important factors to consider when choosing alternatives to KALLAX. Although KALLAX is versatile, the shelves are made of particleboard with a melamine finish, which can limit their load capacity and durability.
In general, modular systems made of solid wood or metal offer significantly higher stability and customization options. For example, modular metal frame systems like those from HAY or String Furniture provide flexible inserts with a variety of compartments, drawers, or boxes, which often feature higher-quality surfaces.
It is also important to define the intended use: Will heavy items be stored? Should the style be modern, rustic, or minimalist? Installation method and transportability also play a role, but in this regard, KALLAX is actually quite practical.
I would be interested to know: Which specific inserts are you referring to? Are you looking for prefabricated boxes, drawer inserts, or simply modular base systems that can be customized individually?
Bayram34
10 May 2022 10:25
GALEO4 schrieb:
Would you question the KALLAX because, for example, the material thickness is an issue for you? Or are you really looking for a completely different design approach?
Good question. My main concern with KALLAX is the thin material and sometimes weak back panel, especially when I want to use the shelf for heavier loads, like books or bulky equipment.
Also, while I find the design functional, it feels a bit too plain for modern living spaces. So, a higher-quality and visually more appealing solution would be very welcome.
I’m therefore looking for something robust and modular, but that also stands out aesthetically.
