ᐅ KALLAX shifted after moving – how to check if it is still stable?
Created on: 24 Aug 2020 17:23
FOLAPAR
FOLAPAR
24 Aug 2020 17:23
I recently reassembled my IKEA KALLAX shelving unit after moving. I noticed that I’m not sure if the furniture still has the same load-bearing capacity as before the move and reassembly. My question is: What is the best way to check if a KALLAX shelf that has been taken apart and put back together still maintains its original stability and load capacity? Are there specific areas I should pay special attention to, such as the joints, shelves, or back panel?
I want to avoid the shelf suddenly giving way under load, as I plan to store quite a few books and heavy items in it. Are there any guidelines, experience, or specific tests that can help me be absolutely sure? Thanks for your advice!
FAZAR
25 Aug 2020 09:47
FOLAPAR schrieb:
How can I best check if a KALLAX shelf, which was disassembled and reassembled after a move, still maintains its original stability and load capacity?
This topic is actually not that simple. The stability of KALLAX furniture mainly depends on the firm connection between the panels and the back panel. After transport, screws or connectors can loosen, or the back panel may warp.
I recommend the following steps:
1. Check all screw connections and, if necessary, firmly reinsert any loose dowels. The connectors at the corners especially need to be secure.
2. Inspect the back panel for damage or deformation. The back panel plays a major role in preventing lateral twisting of the furniture. If the back panel is only slotted in, check if it still fits tightly.
3. Place the shelf on a completely level surface and check if it wobbles or tips. Slight wobbling indicates loose connections.
4. Load test: Start with a few kilograms (a few pounds) before placing heavy items inside.
To accurately determine any change in load capacity: IKEA specifies a maximum load per shelf. Ideally, this should not be exceeded. However, if you load the shelf with a precisely defined weight and notice no deformation or damage, you are generally on the safe side.
Unfortunately, there is no quick and reliable home test for load capacity without measuring equipment.
Exactly: What type of load do you plan to apply, how old is the furniture, and has it been assembled and disassembled many times?
dosogau
25 Aug 2020 13:02
FAZAR schrieb:
Unfortunately, there is no quick and reliable test for load-bearing capacity at home without measuring devices.
Practically simple: Check if the shelf wobbles or deforms under load testing. Inspect and tighten screws. For KALLAX shelves, this is usually sufficient.
Tause
26 Aug 2020 08:18
FOLAPAR schrieb:
Are there any practical experiences or specific tests that can give me absolute certainty?
I find it interesting that "load-bearing capacity" is often mentioned here without knowing the actual load assumptions precisely. IKEA sets limit values for the shelves, but are you aware if the everyday loads often reach or exceed these values?
Another point: especially during moves, the back panel can get damaged, or boards may develop small cracks that aren’t visible at first glance. Such material fatigue affects load-bearing capacity more than people realize.
In my opinion, you shouldn’t rely solely on the strength of the screws but also check whether the wood and the joints themselves are not compromised under load.
For heavy loads, the only safe approach is to consider additional braces or reinforcements—that is often underestimated.
So: how heavy are the items you want to store? And when reassembling, did you tighten all the connection points with the recommended torque without overdoing it? This can make a big difference.
