ᐅ Mounting KALLAX on the Wall Without Drilling – Is It Possible Using Adhesive Tape?
Created on: 12 Jul 2021 18:07
SonmuHello everyone,
I am currently considering mounting an IKEA KALLAX shelving unit on my living room wall without damaging the wall—so without drilling. My specific question is: Is it possible to securely and stably attach a KALLAX shelving unit to the wall using Tesa Powerstrips or a comparable strong adhesive tape?
I know that KALLAX is relatively heavy, especially when loaded with books or decorations, and I don’t want to damage the wall. How well do these adhesive strips actually hold? Does anyone have experience with their load-bearing capacity? Or are there other alternatives that really work without drilling?
I would really appreciate any tips or personal experiences, as I want to avoid unnecessary damage to the apartment but also want to mount the shelving unit safely.
Thanks in advance!
Thanks in advance!
Good evening Sonmu!
That’s a very well-considered question. Generally speaking, KALLAX shelves are not exactly light – depending on how much you put inside, they can quickly add significant weight to the wall.
In my experience, Tesa Powerstrips are great for light items like small picture frames, but they do not provide a permanent solution for a heavy piece of furniture like a KALLAX. The load when fully used is simply too great.
An important point: the durability of this adhesive method depends greatly on the wall material – on smooth, dust-free walls the adhesion can be better than on textured or porous surfaces. Temperature and humidity also play a role.
I personally find it too risky to mount a KALLAX solely with adhesive. I would rather recommend other methods: for example, professional shelf brackets that are sturdy and leave only small holes. Or special wall hooks that may not require drilling, depending on the wall.
If damage-free installation is absolutely necessary, you might consider placing the shelf freestanding and securing it to the wall with an anti-tip device – this way it will be secure and the wall will bear minimal load.
Feel free to share what kind of wall you have and roughly how heavily the KALLAX will be loaded. Then we can provide more specific advice.
Sonmu schrieb:
Is it possible to securely and stably mount a KALLAX shelf to the wall using Tesa Powerstrips or a similar strong adhesive tape?
Sonmu schrieb:
Does anyone have experience with the load capacity?
derrick3413 Jul 2021 07:53Hi,
to put it simply: No, I don’t think Tesa Powerstrips are suitable for a KALLAX. They only hold a few kilograms (a few pounds) and do not provide a long-lasting hold under load.
It’s better to drill a simple hole or place it freestanding.
dunitan schrieb:
In my experience, Tesa Powerstrips are ideal for lightweight items like small picture frames but do not provide a permanent solution for heavy furniture such as KALLAX.I agree with this but would like to question it a bit: Manufacturers of Powerstrips typically specify load limits, usually around 2-3 kg (4-7 pounds) per strip. Assuming you combine several, maybe ten of them, theoretically they could support 20-30 kg (44-66 pounds).
However, this only accounts for static load. A KALLAX shelf, when fully loaded and possibly moved during loading or unloading, also generates dynamic forces and leverage. Especially when mounting a shelf that is not specifically designed for adhesive fixing on a wall, this can quickly lead to failure.
Another aspect rarely discussed here is the type of wall surface, which plays a crucial role. For example, adhesives do not stick well to wallpaper or very rough concrete walls. There is also the risk that removing the adhesive strips will damage paint or wallpaper—exactly what you want to avoid.
I would strongly recommend approaching the topic of “drill-free” mounting with caution and considering alternative solutions, such as self-supporting designs or lightweight shelves specifically made for adhesive mounting.
Sonmu, do you have an estimate of how much weight the shelf will hold? Also, is it a rental property or owned? Sometimes compromises like tension rods or clip systems are better, as they cause minimal permanent damage.
