ᐅ KALLAX treated with wood stain – is it durable?
Created on: 15 Jan 2020 08:37
lelo52
lelo52
15 Jan 2020 08:37
I am currently considering treating my IKEA KALLAX shelving unit with a wood stain to make it more durable and give the wood a nice finish. My main question is whether anyone has experience with this and if the treatment is actually long-lasting, or if the stain tends to peel off, does not adhere properly, or gets scratches under stress that are difficult to repair.
I plan to use the KALLAX mainly in the living room, so it will mainly be exposed to dust, occasional wiping, and light mechanical wear from decorations or books—nothing extreme. Can it be said that a wood stain is a sensible and sustainable way to improve the furniture? Or would the surface be rather sensitive after treatment?
Maybe someone also has tips on how to prepare the surface or which type of stain would be particularly suitable?
Thanks in advance!
GUMARTINA
15 Jan 2020 09:14
Hello lelo52,
Applying wood stain on KALLAX is generally possible. It is important to sand the surface well beforehand and thoroughly clean it of any grease. This usually helps the stain adhere properly.
Make sure to choose a stain that is suitable for furniture and applies in a thin coat.
After applying, it needs time to dry. It is best to apply several thin layers.
This is the fastest and most reliable method that I can recommend based on experience.
danial60
15 Jan 2020 10:23
Hello lelo52,
To answer your question thoroughly, it is important to first understand the material properties of the KALLAX. Standard KALLAX shelves are made from medium-density fiberboard (MDF) with a melamine resin coating, which makes the surface very smooth and minimally absorbent. This means that a regular wood stain, designed primarily for absorbent wood, will hardly adhere permanently without proper surface preparation.
The initial step should be lightly sanding the surface with fine-grit sandpaper (e.g., grit 220) to break the gloss and create some roughness. At the same time, you should clean the surface thoroughly, as dust and grease reduce adhesion.
Afterwards, I recommend applying a primer or bonding agent specifically formulated for plastic or coated surfaces. Only then does it make sense to apply the wood stain.
Regarding durability: Under normal indoor use, the stain can last several years, but with regular wear, minor scratches and abrasion are to be expected. These can usually be repaired by touching up with additional coats.
If the surface is frequently exposed to moisture or heavy mechanical stress, a wood stain is not the best choice, as it does not protect against moisture as well as, for example, a polyurethane varnish.
One more question for you: What effect are you expecting from the stain? Do you want just a change in color, or are you aiming for a completely natural wood appearance?
Best regards!
mifra
16 Jan 2020 07:09
Hello lelo52,
In addition to the previous explanations, I would like to add the following:
1. KALLAX, as already mentioned, is made of coated MDF, so a glaze mainly provides an aesthetic effect rather than real wood protection.
2. It is crucial that the glaze is suitable for smooth surfaces. Often, alkyd resin or acrylic glazes are more appropriate.
3. Surface adhesion can be improved by proper sanding and degreasing.
4. For better durability, using a special furniture lacquer or clear varnish instead of a wood glaze is recommended, as it offers better protection against moisture and abrasion.
5. When applying, make sure to apply thin layers and allow sufficient drying time between coats.
Conclusion: A glaze can improve appearance but should not be considered as full protection. For a longer-lasting, durable solution, a transparent furniture lacquer or clear varnish is more suitable.
If you need more details about the type of glaze or consumer brands, I can provide specific recommendations here.
Elodie
16 Jan 2020 11:47
Hello!
I think KALLAX is great for sprucing up, and a wood stain is definitely a cool way to give it a nice, personalized touch 🙂
However, I would see it more as a small hobby project that’s fun and improves the look, rather than something to be treated like a professional wood furniture piece.
danial60 schrieb:
a wood stain hardly adheres permanently here without proper surface preparation
That matches my experience – just sanding and cleaning helps a lot, but especially at the edges and corners you need to be careful because the stain tends to chip if the base isn’t properly prepared.
mifra schrieb:
for better durability, using a special furniture paint instead of wood stain is recommended
Exactly, if you want it really durable, I’d also go for painting instead. But if the look is more important to you, then definitely give the stain a try. 🙂
In any case, I wish you lots of success and fun with your DIY – KALLAX really offers many opportunities to pimp it up!
If you like, feel free to share how it turned out!
