ᐅ KALLAX Treated with Sunlight Brighteners – Have Stains Appeared?
Created on: 10 May 2021 08:37
Repona
Repona
10 May 2021 08:37
I recently treated an IKEA KALLAX shelf unit with so-called sun bleaches to refresh its appearance and bring out some color. Unfortunately, I noticed afterward that some spots or uneven discolorations appeared on parts of the shelf that were not there before.
Does anyone have experience with treating KALLAX furniture with sun bleaches? Which ingredients might cause these stains, and is there a way to remove or at least reduce them?
For me, it is important to understand whether the stains are caused by a chemical reaction with the material or if they are residues that can be treated.
Thanks in advance for any tips and insights!
nonpra
10 May 2021 09:04
Hello Repona,
Sunlight brighteners can damage MDF or melamine surfaces, leading to discoloration. I would recommend first cleaning with mild dish soap and water, then gently treating the surface with fine sandpaper, if possible.
minan
10 May 2021 10:46
Hello Repona,
you raise an interesting issue that involves some basic chemistry. Sunlight brighteners usually contain substances like hydrogen peroxide or optical brighteners, which are often used in textiles.
KALLAX furniture is mostly made from coated engineered wood (MDF). The surface is usually melamine resin, which is used for protection and decoration but can be sensitive to aggressive chemicals.
If you apply sunlight brightener to this surface, the following effects may occur: the melamine can be attacked and locally swell or discolor. Additionally, some ingredients may chemically react with the color pigments.
When trying to remove the stains, caution is advised because aggressive agents can permanently damage the surface. Have you tried gently wiping the stains with isopropanol or a mild vinegar-water solution?
I would also ask: Was the sunlight brightener applied directly and undiluted, or was it mixed with water? How long was the treatment applied? This information might help to better assess the cause.
Guyju
10 May 2021 12:19
Hello Repona,
I would like to approach this in a more structured way. Often, stains from such treatments are not just surface dirt but a change in the surface itself:
1. Identify the cause:
- Is it superficial residue or an actual color change?
- Melamine resin can react to chemicals and cause 'patchy' spots.
2. Cleaning steps:
- First, try gently cleaning with a pH-neutral cleaner and a soft cloth.
- If that doesn’t work, you can try a slightly damp microfiber cloth with some alcohol (isopropanol).
3. Follow-up treatment:
- Melamine surfaces are very sensitive; if the stain is caused by chemical swelling, often only replacement or repair with a furniture touch-up pen helps.
4. Prevention:
- Bleaching agents or other harsh chemicals are generally not suitable for surfaces like KALLAX.
I hope this helps! If you feel confident, you can try further tests on an inconspicuous spot.
faso31
10 May 2021 14:50
Guyju schrieb:
melamine resin can react with chemicals and cause 'spotty' areas
I would also want to build on that. An important point here is whether the manufacturer of the brightening agent actually approves its use on wood or melamine surfaces. Without such approvals, these spots are almost inevitably due to material incompatibilities.
Are there any specific details or evidence about the strength of the solvents or oxidizing agents in the brightener? I suspect the issue is less about simple contamination and more about localized damage to the protective layer.
I also wonder how evenly the treatment was applied — were all surfaces treated or only certain areas? That can also contribute to the formation of spots.
ryan1
11 May 2021 07:33
Hey Repona!
That sounds really frustrating, but cheer up — these things happen more often than you might think! 🙂
I think it’s great that you’re willing to try such methods on your KALLAX; that takes real courage! Often, lightly sanding the surface after this kind of treatment and then sealing it with a suitable furniture care product can help conceal the damage and even out the colors.
Maybe your shelf will end up looking even better than before! 🙂 Good luck!
