ᐅ KALLAX Shelving Unit Too Weak for Lego Storage Drawers – Alternatives?
Created on: 23 Jul 2024 14:07
astor
astor
23 Jul 2024 14:07
Some time ago, I got an IKEA KALLAX shelf unit to store my Lego bricks and sets in drawers. Unfortunately, I’ve noticed that the designated drawers are not sturdy enough when fully loaded – they tend to bend and sometimes get stuck when pulling them out, which makes access quite difficult.
My question to the community is: Does anyone know of sturdy alternatives to the KALLAX drawers that are specifically suitable for storing and organizing Lego? They should be strong enough to hold a large number of bricks but still fit into a KALLAX shelf or a similar system. Ideally, the drawers would have smooth-running slides or a similar mechanism that can withstand the weight and frequent use.
I would appreciate any recommendations, experience, or even specific product suggestions!
Leote
23 Jul 2024 14:25
I recommend using Elfa drawers (for example, from The Container Store) instead. They are much sturdier and have a smooth sliding mechanism. They don’t fit directly into KALLAX units, but this can be solved with adapter frames.
Nabla64
23 Jul 2024 15:41
Hello astor,
I can relate to your issue with the KALLAX drawers. Here is a brief guide to help you find suitable alternatives:
1. Material choice: Plastic drawers with reinforced bottoms or metal frames are more durable. Also pay attention to the wall thickness.
2. Drawer slides: Full-extension ball-bearing slides are the most robust. Regular drop-in hooks often do not hold well under weight.
3. Dimensions: Since KALLAX measures about 33x33 cm (13x13 inches) inside, you need to ensure precise measurements so the drawers fit properly.
Alternatively, storage boxes from Iris or Akro-Mils offer stackable solutions with sturdy lids. For use in KALLAX, you can experiment with shelves and inserts to secure the boxes.
In summary: Look for stability in materials and good drawer slides, possibly modular solutions instead of traditional drawers.
Davidleo
23 Jul 2024 16:05
This topic is brilliant! 🙂 I had exactly the same problem and switched to sturdy plastic drawers from another furniture manufacturer that fit perfectly into KALLAX. Plus: the drawers slide very smoothly on metal runners, even when fully loaded!
It’s really worth taking a look there – it saves a lot of hassle and makes building even more fun!
Nathanaelk
24 Jul 2024 09:12
astor schrieb:
The designated drawers are not sturdy enough and sometimes jam when pulled out
This is a common issue with KALLAX plastic drawers. To address your question about alternatives, I’d like to take a closer look:
The weakness of the IKEA drawers lies in the material and the sliding mechanism: plastic bottoms can bend under heavy loads, and simple plastic runners wear out quickly with frequent use. The result is jamming and reduced durability.
My suggestions:
1. Look for drawer systems with metal runners (ball-bearing slides) that fit similarly sized furniture. This significantly reduces jamming.
2. Reinforcing the drawer bottoms with additional plywood or MDF panels can be a simple DIY solution if you want to keep the IKEA drawers.
3. When buying replacement drawers, pay attention to the load capacity: values from 15 kg (33 lbs) per drawer are advisable for larger Lego collections.
4. Question: How many sets and bricks do you want to store in one drawer? Are there storage boxes inside the drawer that further affect weight and volume?
If the overall situation becomes clearer, I can recommend suitable products more specifically.
Leote
24 Jul 2024 10:23
Nathanaelk schrieb:
Looking for drawer systems with metal runners (ball bearing slides) that fit similarly sized furniture.
Exactly what I meant. Alternatively, you could also consider tool cabinets, which are often very sturdy, but of course, it’s a matter of appearance and size.
