ᐅ KALLAX Swelled Up After Kettle Accident – What Can Be Done?
Created on: 30 Aug 2024 09:17
Tugayfa
Tugayfa
30 Aug 2024 09:17
A few days ago, I accidentally spilled water on my IKEA KALLAX shelf—specifically, water from the kettle that was quite hot. Since then, the affected compartments of the shelf have swollen noticeably, and the stability has clearly decreased. Since the shelf is made from particleboard or MDF panels, I am aware that the material does not handle water well.
I would like to know if there are any ways to salvage the swollen material or at least stop it from swelling further.
Does anyone have experience with water-damaged KALLAX shelves? Are there preventive measures, repair options, or specific treatments that can reduce the swelling again?
I would prefer not to replace the entire shelf, as it is otherwise in good condition and relatively new.
Thanks in advance for any helpful advice!
Paunon
30 Aug 2024 10:06
Tugayfa schrieb:
Does anyone have experience with water damage to KALLAX shelves? Are there preventive measures, repair options, or specific treatments that can reduce swelling?
Once the material has swollen, it is difficult to fully restore its original condition. Drying is the first step, preferably using circulating air or a fan. Afterward, you can carefully sand the damaged areas to smooth any raised spots. However, you won’t be able to make it completely watertight again.
Dilen
31 Aug 2024 08:54
Paunon schrieb:
Drying is the first step, ideally using circulating air or a fan.
This is a good basic approach, but there are some important details to consider with composite materials. MDF or particleboard is sensitive because it does not have a water-resistant treatment. As a result, the material soaks up moisture deeply, and the swelling caused by the expanded wood fibers and resins cannot be easily reversed by mechanical means.
To best save the shelf, you should follow these steps:
1. Dry immediately: If there is still residual moisture, it really helps to dry the affected area with a fan at room temperature. Artificial heat, such as a hairdryer, can cause localized warping, so it’s better to dry indirectly and gently.
2. Sand swollen areas: Once fully dry, start sanding with fine sandpaper (for example, grit 120) and then move to finer grit (240). The goal is to restore the rough surface to a relatively even level.
3. Fill cracks and uneven areas: If sanding causes holes, you can use wood filler or MDF filler. It is important to create a perfectly smooth surface afterwards.
4. Seal the surface: Since the material is now weakened on the surface due to the damage, a special wood varnish or at least a waterproof sealant is recommended. This will help prevent future swelling.
Important: There is no cleaner or chemical solvent that can “reduce” swelling. The changes in the wood-based material are physical—fibers swell and cannot be shrunk back together.
If the swelling is very severe, for example over 5 mm (0.2 inches), and the stability is greatly compromised, then a complete replacement of the damaged carcass is often the safest solution.
One more question: How extensive is the damage exactly? Is it only the surface, or can you see structural deformations such as warping or bent panels? And how large are the affected areas?
benon
1 Sep 2024 14:23
Dilen schrieb:
However, if the swelling is very severe, for example over 5 mm (0.2 inches), and the stability is greatly compromised, then a complete replacement of the damaged carcass is often the safest option.
This matches my experience. I once had water damage to a KALLAX caused by water spilling from a kettle. The affected panels were heavily swollen, and even after drying for several days, their shape could not be restored.
My recommendation is therefore:
- Dry with air circulation, as already mentioned
- Sanding only for minor damage
- For major swelling: replace the damaged shelf with a matching panel (which can often be purchased individually or custom cut)
- Seal all cut edges and surfaces to prevent further damage
If you have some DIY skills, replacing a shelf is usually much cheaper than buying a new unit. Otherwise, a carpenter can help.
One more tip: when rebuilding, be sure to protect the material from moisture, for example with protective mats under the kettle or doors, to avoid further spills.
Feel free to let me know how things are going on your end, I might be able to offer more advice!
