ᐅ Kallax surface is getting blotchy due to sunlight – any tips?
Created on: 26 Dec 2020 08:23
miles41
I have an issue with my Ikea Kallax shelf. After some time in the sun, spots appear on the surface that look like discoloration and are sometimes dull. The shelf is placed directly by the window and receives regular sunlight, especially around midday. I suspect that the UV rays or heat are affecting the surface. It’s important to me to prevent this since it not only looks unattractive but I also worry that the stability or material might be compromised.
Does anyone here know this problem or have tips on how to best protect the Kallax surface from these spots? Maybe there are special care products, sealants, or other preventive measures? I’m looking forward to your experiences and suggestions, thank you!
Parbo
27 Dec 2020 10:16
LEOIX schrieb:
Discoloration from sunlight is completely normal for furniture in this price and material range.
I agree with that, but preventive measures should not be completely ruled out from the start. The question is what purpose the piece of furniture serves and how long you want to maintain its appearance.
Especially because the surface is not solid wood but a thin melamine coating, it unfortunately cannot be fully repaired. So, if you value the appearance, protecting it and using it carefully are the only ways to preserve its condition.
Therefore, my recommendation is optimizing the location, using UV-protective film, and applying a gentle sealant if needed – everything else will miss the root cause.
