ᐅ Kallax stained after dye accident – is cleaning possible?
Created on: 7 Aug 2020 14:03
Z
zaiddi
A few days ago, I had a dye accident with a fabric on my IKEA Kallax shelf. Some of the white surfaces became stained, probably due to dye residues that leaked during the process. My question is whether and how these stains can be effectively cleaned from the Kallax without damaging or discoloring the surfaces.
The shelf is made of a coated fiberboard, right? I’d prefer not to use harsh cleaners that could ruin the furniture. Do you have any tips or experience on how to remove dye or fabric dye stains from such a surface?
Thanks in advance for your help!
koduga
7 Aug 2020 17:04
That’s really unfortunate, zaiddi. I once had a similar issue, but with coffee on light-colored laminate flooring. I still remember how frustrating it was.
In the end, I accepted that the stains wouldn't come out completely because several attempts had already slightly damaged the surface. Maybe a small touch-up with matching paint pens is worth trying if cleaning doesn’t help.
Don’t get too stressed, sometimes less is more. 🙂
JAPLO
7 Aug 2020 18:13
If mild methods and isopropanol don’t work, you can carefully try using an eraser – sometimes it can remove such stains.
That’s a good tip. An eraser-like cleaner or a gentle plastic sponge can help with light stains without damaging the coating too much. However, you should avoid applying too much pressure or using abrasive cleaners.
faso31
7 Aug 2020 19:32
It is interesting that isopropyl alcohol and mild cleaners are often mentioned here, without specifying the type of paint in more detail.
Which exact paint has spilled? Plastic-based fabric paints can possibly be more stubborn than, for example, water-based textile paints. This difference could be crucial for choosing the right cleaning method.
Does anyone have reliable experience with specific types of paint on Kallax?
Z
zaiddi
7 Aug 2020 20:06
faso31 schrieb:
Which exact color has leaked? Plastic-based fabric paints can sometimes be more stubborn than, for example, water-based textile paints.
Thanks for bringing that up! It is a water-based reactive dye that should normally be well fixed. However, something apparently went wrong during the dyeing process and it affected the surface.
So far, I seem to be seeing some initial success with isopropanol, but it’s not yet satisfactory.
Are there any gentler specialized cleaners for melamine resin that might be better suited for these kinds of stains?
reni45
8 Aug 2020 08:41
For water-based paint spots, a damp cloth with lukewarm soapy water is often enough—rub several times. Otherwise, try special furniture cleaners available at hardware stores.
Jodyro
8 Aug 2020 10:15
Correct, do not use solvents like acetone! Only mild cleaners and low-concentration alcohol should be used. It becomes more difficult if the stains are older.
