ᐅ Kallax Floors Splintering at Cut Edges – What Can Be Done?
Created on: 27 Mar 2020 09:18
Janfra
Janfra
27 Mar 2020 09:18
I have a problem with my Ikea Kallax shelves, where the shelves often chip or fray at the cut edges. I cut some shelves to size myself to fit the shelf unit individually to the room. I noticed that especially the cut edges I processed with a jigsaw are quite rough and the surface material chips off.
Does anyone have experience with this issue? I would like to know which methods or materials might help to keep these cut edges clean and free of splinters. Should I use a different saw, apply edge banding, or are there special sealants? Tips on tools would also be helpful, but for now I am only looking for DIY solutions without heavy machinery.
Looking forward to useful advice and shared experiences!
Germanro
27 Mar 2020 11:03
Janfra schrieb:
Which methods or materials help to keep the cut edges of Kallax floors clean and free of splinters?
The simplest solution is to sand the edges with fine sandpaper (grit 180-220) and then seal them with clear wood glue or varnish. This prevents further fraying.
Surela
28 Mar 2020 14:55
Janfra schrieb:
Does anyone have experience with this problem? I would like to know which methods or materials could help keep these cut edges clean and free of splinters.
Your issue is common when working with particleboard or laminated wood-based panels, such as the shelves in Kallax units – the cut edges are often the weak point. It is important to stabilize the cut edge well before sawing. I recommend applying painter’s tape or masking tape along the cut line before cutting. The tape helps prevent fiber tear-out by holding the surface together. Then saw precisely along the edge.
Choosing the right saw is also important: a jigsaw with a fine-toothed blade or a track saw with a fine tooth count are better suited. Coarser blades tend to tear out the edge. After cutting, carefully sand the edges with fine-grit sandpaper, around 240 to 320 grit, to smooth the edge.
Afterward, I suggest treating the surface with edge glue. These special adhesives penetrate and seal the edge to prevent splintering. Alternatively, you can apply a thin coat of clear acrylic or polyurethane varnish, depending on what looks best for your Kallax shelf.
How have you been making the cuts so far? Have you tried using painter’s tape or protective tape?
KODAN32
29 Mar 2020 17:47
Surela schrieb:
I recommend using painter’s tape or masking tape along the cut line. The tape prevents fraying by holding the surface together.
Good tips! I’d like to add a brief step-by-step guide:
1. Preparation: Apply painter’s tape along the cut edge to prevent fraying.
2. Tool selection: Use a jigsaw with a fine-toothed blade, for example, one designed for laminate flooring.
3. Cutting: Saw slowly and with steady pressure – cutting too fast increases the chance of chipping.
4. Finishing: Gently sand the cut edge with fine sandpaper (grit 220 or higher), being careful not to press too hard.
5. Sealing: Apply wood glue or a special edge adhesive to the cut edge using a brush or your fingertip, and allow it to dry thoroughly.
6. Optional: For an even smoother finish, you can apply a thin coat of clear varnish afterwards.
If you want to avoid using an edge strip, this procedure is best to effectively prevent splintering and fraying.
One more tip: test the method on a scrap piece first to achieve the best results. This way, you can fine-tune the speed, pressure, and tool settings before working on the final flooring.
How large are the pieces you are cutting, and what exact tool are you using? That way, we can give more targeted advice on the settings.
