ᐅ KALLAX Shelves Sliding – How to Secure Them?
Created on: 19 Jan 2022 18:27
sanJoshua
Hello everyone, I have a KALLAX shelving unit that stands directly on the floor, and I’ve noticed that the shelves inside the compartments often shift or slide out of place. This causes the shelves to no longer lie completely flat and stable, which is especially problematic in compartments with heavier loads. I’m looking for a way to securely prevent the shelves from slipping without resorting to aggressive methods like screws or glue, since I want to be able to move or remove the shelves occasionally. Does anyone have experience with a practical, preferably residue-free solution that doesn’t require special tools? What methods are recommended, and what should I keep in mind to ensure the shelves remain stable but still flexible? Thanks for your advice!
Gino38
20 Jan 2022 12:48
In a similar situation, inserting small "wedges" at the front edges of the shelf board helped me a lot. These wedges can be made from sturdy foam rubber and are carefully pressed into the side walls of the compartment to create tension. The slight pressure keeps the shelves fixed in place without allowing them to slip.
The advantage is that these wedges are flexible to use, require no adhesive, and can be removed if needed. They are ideal when the space between the shelf board and the side wall is slightly larger, which is often the case with KALLAX.
bupar
21 Jan 2022 08:33
Gino38 schrieb:
Inserting small "wedges" at the front edges of the shelf board helped me a lot.
This method is indeed recommended, especially when there is no longer a tight fit or if the assembly is somewhat difficult. It is important that the wedges are not too thick, so the board does not warp or lift.
Additionally, I would recommend applying non-slip film or thin rubber (about 1-2 mm (0.04-0.08 inches) thick) to the underside of the shelves to improve grip from below as well. This way, the securing works from both sides, making it particularly stable.
Finally, I suggest checking after a few weeks to see if the materials have settled or require adjustment, since some adhesive or rubber materials may lose effectiveness over time.
