ᐅ KALLAX Shelf Replaced – Now Everything Creaks?
Created on: 13 Nov 2024 07:42
MEONATHA68
I recently replaced a shelf panel in my IKEA KALLAX shelving unit because the old one was damaged. Since then, the entire unit has been creaking loudly with every touch, sometimes even under light load. Before, the shelf was completely silent.
My question is: What could be causing the creaking? Could it be related to the installation of the shelf panel, or is it normal for the individual parts to make some noise?
I have tightened all the screws and made sure the shelf fits exactly, but the problem persists. Is there a way to stop the creaking without having to disassemble the whole unit?
I look forward to your assessments and troubleshooting tips. Thanks in advance!
Davidleo
14 Nov 2024 08:12
Hey, this is an exciting challenge! 🙂
I once had a similar creaking issue with my KALLAX, and what worked really well for me was using thin felt pads exactly at the support points of the shelf panel. That almost completely eliminated the creaking!
Also, if the board is slightly thinner than the original, it can cause movement. You might want to try adding one or two small wooden blocks as spacers to ensure everything fits snugly and securely.
Keep at it, you’ll definitely get it figured out! 🙂
nolan
14 Nov 2024 10:23
One quick addition:
Sometimes it also helps to slightly loosen the screws on the cabinet frame, insert the shelf, and then tighten the screws evenly. This way, the pressure is distributed better and squeaking noises can be reduced.
