ᐅ KALLAX Shelf Does Not Fit the Planned Wall – Should I Saw It or Replace It?
Created on: 29 Jun 2023 20:37
kodi51
kodi51
29 Jun 2023 20:37
Hello everyone, I’m facing the following issue: I have planned to install a KALLAX shelving unit from Ikea against a specific wall. However, it doesn’t fit properly in the planned width – it is about 8 cm (3 inches) too wide for the wall. Now I’m considering whether I should simply saw the shelf to make it fit or if it would be better to exchange it for a narrower unit from Ikea that fits from the start.
The shelf is generally sturdy, but I don’t want to compromise the appearance, and I don’t have any special tools for fine cuts. I’m also wondering if sawing the wood panels and the backboard would significantly affect the stability.
Do you have experience with adjustments like this on KALLAX or similar shelving systems? Or would you recommend exchanging it because of the material properties and the time involved? I would appreciate any advice!
bupar
29 Jun 2023 21:04
Basically, KALLAX shelves are made of coated particleboard, which can easily chip or splinter along the edges when cut. The decorative surfaces and back panels are especially prone to damage from imprecise cuts.
kodi51 schrieb:
whether cutting the wooden panels and backboard would compromise the stability too much.
The stability can indeed be affected, as the fixed attachment points of the back panel are often crucial for the overall rigidity. If you have the right tool—ideally a plunge saw or a very fine circular saw blade—that could be an option.
If not, I would recommend exchanging it for a smaller or narrower KALLAX model, which are available in different widths. This will also save you from extra work and potential quality issues.
blapau
30 Jun 2023 07:18
I agree with bupar that cutting is technically possible but often complex and not without risks. Losing a perfectly straight edge will be very noticeable later on. The back panel is usually just attached by clips or nails – in case of doubt, it can be replaced or swapped out for a thinner plywood sheet.
kodi51 schrieb:
Optics should not suffer
If aesthetics are your top priority, exchanging or purchasing a new one makes more sense. In addition, this way you can definitely still use the shelf without any loss of stability.
joro10
30 Jun 2023 09:39
Cutting is possible if you work precisely and carefully. However, for a width difference of 8cm (3 inches), I prefer to choose the smaller KALLAX and avoid the extra effort.
juMira46
30 Jun 2023 10:14
Hey, I really admire that you want to customize the shelf! 😊
But honestly: a bit of cutting is doable, but it requires a lot of effort and potentially some stress. The area where you cut can easily develop rough edges or even minor damage. And nobody wants a shelf that looks damaged in the end, right? 😉
If the shelf is only 8 cm (3 inches) too wide and you have the budget for it, your future shelf will probably be happier with an exchange rather than a cutting attempt. That way, you’ll definitely get a perfect fit without any concerns about stability or appearance.
I wish you the best of luck, whatever you decide!
bupar
1 Jul 2023 08:55
As an addition: If you decide to cut, I recommend making the cut with a sharp fine-toothed saw or a plunge saw with a guide rail. Apply painter’s tape beforehand to reduce splintering.
Regarding stability: The back panel of KALLAX units can be trimmed and reattached, for example using thin nails or screws.
blapau schrieb:
The back panel is usually just slotted in or nailed on
That’s correct, so the back panel can be modified, but the stability should be carefully checked before installation. Exchanging the unit is often the more permanent solution, if possible.
