ᐅ Using a KALLAX shelf unit as a wardrobe—do you have any tips?
Created on: 22 Feb 2024 08:37
Drabar47
Drabar47
22 Feb 2024 08:37
I’m considering approaching my wardrobe project a bit differently and thought about using the IKEA KALLAX shelving unit as a base. My idea is to use the KALLAX as a modular wardrobe, especially for smaller rooms or bedrooms where a traditional wardrobe might be too bulky.
The question I have is: Do you have practical tips or experiences on how to best use the KALLAX as a wardrobe? Specifically, I’m interested in how to integrate clothing rods most effectively, whether drawers or boxes are recommended, and how to keep the appearance neat and durable.
Maybe also suggestions for additional fixtures or modifications to improve stability? I would also appreciate advice on optimizing storage space and organization.
Thanks in advance!
TRADI
22 Feb 2024 09:15
Hello Drabar47,
I think your idea of using the KALLAX shelf as a wardrobe is very practical—especially because it is so flexible.
A proven method to add hanging rods is to install angled rod holders on the sides or inside the compartments. IKEA also offers separate rods that you can slide in and hang from the shelves. These are sturdy enough for shirts and light jackets.
For heavier garments, small metal pipes fixed with drilled holes are a good option. However, make sure to secure the unit to the wall to prevent tipping, as the load may then be unevenly distributed.
You can simply place drawers as boxes inside the shelf. The fabric boxes from IKEA themselves are particularly popular—they are easily accessible and help keep things organized, for example for underwear or accessories.
Finally, I recommend protecting any protruding shelf feet with laminate or felt pads on the floor, especially if you move the shelf frequently.
Good luck!
labar43
22 Feb 2024 10:02
Hey Drabar47,
wow, your idea is brilliant! 🙂 I also converted my KALLAX shelf into a wardrobe by using tension-mounted clothing rods on the sides, which are very sturdy. This works great because you can use the individual compartments differently, and it feels much more open than a traditional wardrobe.
Tip: Use colorful fabric boxes to add more color and brighten up the look! It immediately looks much friendlier and more personalized 🙂 I also fit handy scarf holders and small baskets for socks in there perfectly.
I used to get frustrated with clutter a lot, but with a solution like this, tidying up even becomes fun! You can also attach small hooks on the outside to hang belts or bags.
Don’t get discouraged if it takes some trial and error at first! This is really cool :-) Good luck!
BOMILAN
22 Feb 2024 12:18
Small and straightforward:
– Attach metal clothes rods directly with screws
– Fabric boxes for small items
– Double slatted bed base cover for increased stability
Simple and functional.
pikin
22 Feb 2024 14:45
To use the KALLAX shelving unit effectively as a wardrobe, I recommend the following points:
1. Clothes rail integration: Use sturdy metal pipes with wall mounting for stability. Side mounting minimizes stress on the structure.
2. Shelf cube usage: Arrange drawer boxes for underwear and smaller textiles; fabric boxes are particularly effective.
3. Appearance: Uniform colors for the boxes and optionally shelf doors to close the compartments create a tidy look.
4. Safety: Due to weight distribution, the shelving unit must be securely fastened to the wall.
5. Storage optimization: Fold clothing space-efficiently or use organizers.
This structured approach increases functionality and durability.
For an overview, I recommend visiting furniture construction forums or IKEA hacks for inspiration.
fredle
22 Feb 2024 18:22
Hello Drabar47,
here is a brief guide on how to organize your KALLAX as a wardrobe:
1. Planning: First, create a sketch of the room layout and the space needed for clothing.
2. Clothes rail: Purchase sturdy clothes rails with wall brackets, and mount them horizontally between two or three KALLAX compartments. Metal pipes with a diameter of at least 2 cm (0.8 inches) are ideal.
3. Boxes & drawers: Use fabric boxes for easier access and coordinate their colors with the room design.
4. Stability: To improve stability, secure the shelving unit to the wall with angle brackets. This helps prevent tipping.
5. Organization: Hang similar clothing items together and use hooks on the outer sides for accessories.
Common mistakes: choosing clothes rails that are too long or not securing the unit—this leads to instability.
I hope this helps you!
