ᐅ KALLAX Shelf After Moving: Edges Are Splintering – What Can I Do?
Created on: 17 Mar 2022 14:37
manricbenM
manricben17 Mar 2022 14:37Hello everyone,
I recently took my KALLAX shelf out of storage after moving and started reassembling it. I noticed that one of the outer edges of the wood is heavily splintered, leaving the surface rough with small pieces sticking out or missing. This surprised me because I had treated the shelf carefully. My question is: What are the proper ways to repair this kind of edge damage or at least improve its appearance? Are there specific repair products or techniques that can effectively hide the splintering and restore the shelf’s stability? I prefer not to improvise but to find a durable solution that also works for furniture made of particleboard or laminated MDF. I would appreciate any advice!
Hello manricben,
I can understand your concern well, as KALLAX shelves are usually made of particleboard with a thin melamine resin coating, which makes the edges particularly vulnerable to mechanical damage. During a move, the stress on the edges is often underestimated, causing splintering.
First, the question is how extensive the damage is and whether the surface of the edge is still intact or completely chipped off. If it is only minor chips, you can treat them as follows:
1. Remove large splinters with a sharp knife or sandpaper. Use fine sandpaper (grit around 220) to avoid further damage to the surrounding surface.
2. For uneven areas, use a repairable wood filler or a filler specifically designed for particleboard. Apply it carefully with a narrow spatula and smooth it out.
3. After drying, sand the area again so that it is flush with the surrounding surface.
4. To restore the overall appearance, colored furniture markers or paints suitable for melamine-coated surfaces are available. This requires some skill, as the color tone and gloss level can vary.
If the plastic coating on the edge is severely damaged, it might be useful to apply an additional edge protector (protective profile) made of plastic—these are available as self-adhesive films or strips at hardware stores.
For lasting reinforcement, you can also carefully seal the shelf edges with edge protection if they are frequently subjected to stress.
To give you better advice depending on the damage: How big exactly is the damaged area? Are there possibly loose parts or splintered pieces after the move that might still be under tension?
I hope this helps you for now.
praWarre6918 Mar 2022 12:52Laukau5 schrieb:
If the plastic coating on the edge is severely damaged, it might be a good idea to add an additional edge protector (protective profile) made of plastic – these are available as self-adhesive strips or molding in hardware stores.I completely agree with that! A bit of edge protection is like a little guardian for your shelf – it protects, looks nice, and gives the whole thing a fresh touch. 😊
Also, if you’re a bit creative, you can choose protective strips with a wood finish or in bright colors, depending on how much character your living room needs. In my opinion, nothing makes furniture more appealing than a small personal touch.
And seriously, after moving, a little extra protection is definitely worth it. Simply painting over a chip usually doesn’t last long. So it’s better to put in a bit of effort and secure everything well – it will save you hassle and repeated repair work 😉
By the way, if you fill it with wood filler, make sure it’s really suitable for furniture! Not every filler is the right match. Good luck!
