ᐅ KALLAX already repaired multiple times after four years – is that normal?
Created on: 18 Oct 2022 19:37
GosarHello everyone,
about four years ago, I bought a KALLAX shelving unit from IKEA, which I still use daily. Unfortunately, I have had to repair the shelf several times because various parts, such as shelves and connectors, either broke or became loose.
My question is: Is it normal for a KALLAX shelf to require multiple repairs after only around four years, despite not being heavily loaded?
I am quite technically skilled and take good care of the furniture, but signs of wear are still noticeable. Has anyone else had similar experiences with KALLAX or comparable shelving systems? Or do you have any recommendations on how to improve durability without having to replace the entire unit?
Thanks in advance for your feedback!
Gosar schrieb:
I bought a KALLAX shelving system nearly four years ago, which I still use daily. Unfortunately, I have had to repair the shelf several times already because various components like shelves and connectors broke or became loose.The KALLAX system is generally designed for moderate loads and is usually considered durable—at least with proper use. However, after four years and multiple repairs, this does not necessarily seem typical.
Problems often arise from overloading individual compartments, which accelerates material fatigue. Irregular loads or exposure to moisture can also weaken the particleboard material. It might be helpful to check the exact load for each compartment and, if necessary, reduce stress by adding extra supports.
Furthermore, I recommend regularly inspecting the connecting elements and using high-quality replacement parts in advance if the original screws or dowels do not hold well.
Gosar schrieb:
Is it normal for a KALLAX shelf to require multiple repairs after only about four years, even without excessive use?Objectively, KALLAX is priced in the entry-level to mid-range segment and uses MDF panels with a foil coating. These panels are susceptible to moisture and mechanical stress over time. Four years with multiple repairs is unfortunate but highlights the limitations of this material.
Factors such as humidity, temperature fluctuations, and load distribution affect durability. My advice: check if moisture has penetrated the panels – this is often the cause of swelling and cracks. This accelerates material fatigue and makes damage more likely.
Additionally, reinforcing the shelves (for example, with metal brackets) can improve stability.
Niclas schrieb:
My advice: check if moisture has penetrated the material – this is often the cause of swelling and cracks.That sounds very plausible. I can understand how frustrating it is when you can’t just buy a piece of furniture and use it worry-free for years, but instead have to keep repairing it.
Giagau schrieb:
It might be helpful to check the exact load on each compartment and, if necessary, relieve it with additional supports.I would like to emphasize this as well, because sometimes the causes are small, such as too many heavy books in just one compartment, which can weaken the material over time.
If you want to keep using the shelf, I would also be interested in how, for example, you assemble it and whether it is securely attached to the wall – because safety always comes first.
In any case, don’t feel alone with the problem; these things happen often. Sometimes, with a bit of patience and creativity, you can get significantly more use out of the furniture.
I would like to revisit the basics in case it might be helpful:
The KALLAX shelving unit is made from engineered wood panels and is subject to the usual load and environmental factors that affect similar furniture.
It is important to assemble it exactly according to the instructions, because, for example, using the wrong screws or missing fasteners can reduce stability. IKEA also recommends securing the unit to the wall to prevent tipping and to distribute the load more evenly.
Additionally, the maximum load per shelf should not be exceeded (usually about 13kg (29 lbs) per shelf for KALLAX).
If the unit requires multiple repairs despite following these guidelines, it would be useful to identify the weak points specifically.
When it comes to connectors and shelves, high-quality aftermarket parts from hardware stores can often be very effective. This approach often extends the lifespan more than simply replacing the defective IKEA original parts.
I hope these tips are helpful to you!
