ᐅ Kallax shelf reinforced with wood glue after water damage – any experiences?
Created on: 25 Dec 2023 09:17
naucelia
Good morning everyone,
I have a somewhat specific question and hope to get your experiences and opinions: My Ikea Kallax shelving unit was partially damaged by water some time ago, especially at the edges and joints, which have now unfortunately become a bit soft and wobbly. I don’t want to replace the entire unit, but I’m considering reinforcing the damaged areas with wood glue to restore stability.
So I’m specifically interested in whether any of you have experience reinforcing a Kallax or similar shelving unit after water damage using standard wood glue. How effective is this in terms of load-bearing capacity and durability? Does this technique actually get you far? Are there better alternatives if you don’t want to buy a new unit?
I would also appreciate any advice on preparation, glue application (including on porous, slightly swollen material), and finishing the repaired areas.
Thanks in advance for your tips!
Davidleo
26 Dec 2023 12:47
Great to see so many helpful tips here! 🙂
I once repaired a similar Ikea shelf with wood glue after water damage had softened the lower shelves. I used PU glue, sanded off the laminate beforehand, slightly roughened the surfaces, and clamped everything firmly. The result turned out very sturdy; the shelves have held up perfectly for 2 years now.
What I also recommend is sealing the glued areas with one or two coats of clear varnish once the glue has dried. This creates an additional protective barrier against moisture.
If you reinforce the shelf properly, you'll definitely save a lot of money and the unit will last a long time again. Good luck with the repair!
Lucien
27 Dec 2023 09:05
naucelia schrieb:
Thanks also for the tip about PU glue – I wanted to try that as well.
PU glue is preferred, especially in slightly damp areas, due to its chemical reaction with moisture that enhances adhesive strength.
For greater stability, it is recommended to combine gluing with metal mounting brackets at the edges.
After drying, ensure proper ventilation, as PU glue releases CO2 during curing, which can produce an unpleasant odor.
This noticeably increases the durability of the repair.
