ᐅ KALLAX placed on a stone floor – is it necessary to use a base or padding underneath?
Created on: 6 May 2023 14:37
Jafiix
Hello everyone, I am currently planning to place a KALLAX shelf from IKEA directly on my stone floor in the living room. I am wondering if it is necessary to use some kind of underlay to protect the floor or the furniture itself, or if the KALLAX can be placed directly on the floor without anything in between without causing damage or affecting its stability. Does anyone have experience with this, especially on smooth stone floors? I know that for some furniture pieces, felt pads are recommended, but I don’t want to give a general recommendation without knowing if it is really necessary in this case or if the KALLAX’s construction prevents any issues. Thank you very much for any helpful answers!
Davidleo
7 May 2023 08:51
Hey Jafiix! It’s great that you’re asking such detailed questions here! 🙂
I once placed my KALLAX directly on a stone floor without any underlay — after a short time, there were small scratches and the shelf slipped slightly.
Then I simply attached felt pads underneath, and since then everything has been stable and the floor has stayed in perfect condition!
This is really an affordable and easy solution that I can definitely recommend to everyone. So, I clearly say: using an underlay is worth it and saves you trouble later! 🙂 🙂
Leland
7 May 2023 09:13
Felt pads or thin rubber mats are effective. They prevent scratches and provide stability. It's a simple solution, just stick or place them under the corners.
rigau
7 May 2023 10:07
I would recommend rubber pads because they don’t slip and protect the stone floor. Felt pads also work but can become more slippery when wet.
Jafiix
7 May 2023 16:45
Thanks for your tips so far!
Surela schrieb:
I’m curious: How long do you plan to keep the shelf there, and will it be heavily loaded? Also, is the floor completely level or are there small uneven spots?
Today, I checked the floor again with a spirit level; the unevenness is so minimal that it should hardly matter in practice. My main focus now is definitely on protection and slip resistance.
One more question to the group: How about moisture? Sometimes, drafts and slight cold come through the windows onto the stone floor—could this affect the performance of a felt pad or rubber feet? I want to avoid the underlay absorbing moisture over time or causing mold.
Charles
7 May 2023 18:22
Jafiix schrieb:
What about moisture? Sometimes drafts and slight cold come through windows onto the stone floor, could that affect the performance of felt underlays or rubber pads?
Good question. Moisture can indeed be an issue, especially with felt underlays, as they can absorb water and remain damp for longer periods. Rubber pads, on the other hand, are water-resistant and not affected by moisture. However, it is advisable to regularly check all underlays and ensure adequate air circulation to prevent mold growth.
My recommendation: If moisture is a concern in the room, opt for rubber-like materials or special furniture pads made of plastic, which are water-resistant.
DULIS
8 May 2023 08:12
Rubber pads are waterproof, non-slip, and provide good floor protection. Felt can absorb moisture, which over time can reduce its durability.
