ᐅ Kallax paint is chipping – how to repair it?
Created on: 27 Nov 2024 08:37
PASCALNON
I recently assembled a new KALLAX shelf unit from IKEA, which I ordered with a matte finish. Unfortunately, I have noticed that the finish is chipping off in several places, especially along the edges and corners. The chips are not very large, but the damage looks quite unattractive, and I definitely want to make the shelf durable and visually appealing again.
My specific questions are:
1. What is the best way to repair the peeling finish without the repair spots being too noticeable?
2. What materials and tools do I need for this?
3. Are there any preparatory steps I should take before repainting, such as sanding or priming?
4. Are there particular paints or coatings especially suitable for KALLAX to prevent this from happening again?
I have some DIY experience but want to approach the repair properly and would appreciate tips from professionals or anyone who has done this before.
Thanks in advance!
Filippo
28 Nov 2024 09:21
PASCALNON schrieb:
Does anyone have experience whether an acrylic lacquer is sufficient or if a two-component lacquer might be better?
Very good question!
Water-based acrylic lacquers are generally very user-friendly, low in odor, and dry relatively quickly. They provide good protection for light to moderate wear.
Two-component lacquers (2K lacquers) are harder and more resistant to abrasion, scratches, and chemicals, but they are more challenging to apply, have a stronger odor, require precise mixing ratios, and longer drying times.
For a KALLAX unit in a home office that will experience heavier use, a 2K lacquer can definitely make sense—if you don’t mind the handling or can get help at your local hardware store.
If you want to keep it simple, a high-quality acrylic lacquer applied in several thin, complete, and neat coats can work well. I also recommend adding a protective clear coat (matte or satin finish) afterward.
Pretreatment is important too: sanding and priming, especially on repaired areas.
Feel free to let me know if you’re interested in 2K or acrylic lacquer; I can then provide more detailed product recommendations and advice on proper protection.
juMira46
28 Nov 2024 10:44
Hi Pascalnon,
I find this discussion really helpful! 🙂
Just to say: it’s a matter of personal preference, but I wouldn’t cut corners on quality. Especially for frequently used furniture like the KALLAX, it’s essential that the paint not only looks good but also lasts.
If acrylic paint feels uncertain to you, go ahead and try the 2K paint; the result feels really durable and you’ll enjoy it for longer.
And remember: when sanding, slightly round the edges so no new stress points appear during repainting. Otherwise, the paint won’t know how to handle the stress 😉
Good luck, and let us know how it turned out! 🙂
neoren
29 Nov 2024 14:16
In short: Acrylic paint is sufficient for normal wear. However, if the surface is often bumped or exposed to moisture from hands, a two-component (2K) paint is worth considering. In both cases, sand thoroughly, prime, and allow to dry properly.
