ᐅ Kallax shelves slip too easily on tile floors – is an anti-slip mat suitable?
Created on: 25 Aug 2022 09:12
lumatteo48
I have a Kallax shelf on my bathroom floor, which is fully tiled. Unfortunately, I notice that the shelf tends to slip quite easily on the smooth tiles, especially when I open the doors or place heavy items inside.
Now I am considering whether an anti-slip mat under the Kallax shelf would be useful to reduce the risk of slipping. Has anyone had experience with anti-slip mats under furniture on tiled floors?
I am particularly interested in which materials work best, whether the mats leave residues afterward, and if there are alternatives to keep the shelf securely in place on the floor.
I appreciate any tips and recommendations!
Timofa
26 Aug 2022 08:16
One more practical tip:
When buying a non-slip mat, make sure it’s not too "fluffy," otherwise the shelf will wobble again. 🙂
A thin but grippy mat is ideal, so nothing slips and everything stays level.
Also: If you’re not constantly moving the Kallax, the mat can compress a bit after a few weeks and then it will hold really firmly!
O
ODINFLO
26 Aug 2022 09:31
It is also important that the mat is not too porous. Some cheap products absorb moisture, which can cause issues on tiles.
I would always recommend a mat with a closed surface that is easy to clean and does not allow moisture to pass through.
tutan
26 Aug 2022 10:47
lumatteo48 schrieb:
Whether the mats leave any residue later on
Well, I once had a non-slip mat under my shoe cabinet, and over time, nothing peeled off or got discolored at all.
The key is just to keep the tiles clean regularly so that neither dirt nor adhesive residue builds up.
A good mat really makes a big difference and is a super simple solution. It’s a bit like a little everyday magic trick 😉.
dosogau
27 Aug 2022 07:15
Rubber anti-slip mats are the best choice. A small tip: replace the mat after several weeks if it loses grip.
Alternative: Anti-slip pads under each corner. However, mats tend to provide more stability.
