I recently got a Kallax shelf unit converted into a workbench because I wanted more storage space for DIY projects. However, I’ve noticed that when using it as a workbench, it quickly accumulates a lot of dust and wood chips. Especially when sanding or sawing, the dust spreads everywhere on and inside the compartments.
I’m curious if any of you have experience with this and if there are effective solutions to manage the dust problem on the Kallax workbench. In particular, I’d like to know if the shelves can be better sealed or protected, or if there are recommended additional dust protection measures.
I look forward to your tips and experiences!
Thanks for all the helpful tips so far!
That sounds like a clean solution, I’ll check the hardware store for suitable materials.
I don’t want to make major structural changes to the shelving since I can’t rebuild it completely. Small modifications like attaching panels or curtains are fine. I could set up dust extraction with the right equipment, but currently I don’t have a permanently installed dust extraction system.
If anyone has good tips for temporary dust reduction right at the work area (e.g., tool attachments or working methods), please share!
LOGEMIN schrieb:
self-adhesive magnetic strips for plexiglass
pauPierce schrieb:
How flexible are you with the redesign?
rushahin schrieb:
Tips for temporary dust reduction at the worksiteTo limit dust directly without a permanently installed extraction system, I can recommend the following methods:
- Use hand sanding blocks with integrated dust extraction (if possible)
- Use sanding machines with dust collection bags
- Work at a mobile extraction table on casters, which can be temporarily placed in front of the Kallax unit
- Use extraction brushes on saw blades or drills (so-called dust catchers)
Dampening the surface before sanding also reduces dust dispersion somewhat. Not always practical, but useful in some cases.
reoleon4711 Aug 2021 09:12I find this topic really interesting! 🙂
I lined my workspace with a thicker protective fleece that catches sawdust. Then you can simply vacuum it up or throw it away, super easy!
Maybe something like this could also be adapted for the Kallax, for example a mat in the lower compartments that you change regularly!
mo-hau schrieb:
Sanding machines with dust bags and extraction brushesThanks, that’s already a good direction! At the moment, I have a simple handheld sander without any attachments, but I’m already looking into dust extraction kits for the devices.
reoleon47 schrieb:
Protective fleece in the lower compartmentsI also find the idea of using fleece practical and easy to implement. This way, at least the coarse chips can be caught and disposed of more easily.
I will try this step by step and get back if I have further questions. Thanks to everyone for the valuable input!
