ᐅ Kallax on the Workbench – Dust Issues?
Created on: 10 Aug 2021 08:17
rushahin
rushahin
10 Aug 2021 08:17
I recently got a Kallax shelf unit converted into a workbench because I wanted more storage space for DIY projects. However, I’ve noticed that when using it as a workbench, it quickly accumulates a lot of dust and wood chips. Especially when sanding or sawing, the dust spreads everywhere on and inside the compartments.
I’m curious if any of you have experience with this and if there are effective solutions to manage the dust problem on the Kallax workbench. In particular, I’d like to know if the shelves can be better sealed or protected, or if there are recommended additional dust protection measures.
I look forward to your tips and experiences!
LOGEMIN
10 Aug 2021 08:42
Hello rushahin,
First of all: The issue with dust when repurposing a Kallax unit as a workbench is indeed relevant, since the shelf was not originally designed for workshop use.
1. Sealing the compartments: You can cover the backs with thin plexiglass or another smooth panel, which will prevent dust from entering from the rear.
2. Protective film or curtains: Especially the open compartments can be fitted with removable films or curtains to keep dust out.
3. Work surface: A removable worktop with edge trims on top helps to avoid spreading dust onto the shelf components.
4. Vacuum connection: If you use power tools, make sure the dust extraction port is functional to reduce dust exposure.
In summary, I recommend sealing the open areas as best as possible and vacuuming targeted. Without fundamental modifications, it will be difficult to eliminate dust completely.
Devin
10 Aug 2021 09:03
Attach dust protection film to the shelf compartments and, if possible, work with a workshop vacuum cleaner. You should do this to avoid dust spreading everywhere.
pauPierce
10 Aug 2021 09:45
Hello rushahin,
to better understand the issue: What kind of tasks are you performing on the Kallax workbench exactly? Are you often working with sanding or sawing, or is it more assembly work? It would also be helpful to know if the shelf unit is directly on the floor and how well ventilated the workspace is.
Dust distribution strongly depends on air circulation and the type of work being done. Sanding produces fine dust that tends to settle in all the gaps and crevices. An additional tip: you can equip the shelf compartments with transparent doors to keep dust out without needing to rebuild the shelf completely.
Also: Has the surface been sealed or painted yet? Otherwise, dust sticks more easily. A smooth surface finish makes cleaning easier.
reoleon47
10 Aug 2021 10:14
It's brilliant that you're using a Kallax as a workbench! 🙂 I've thought about that too!
Dust can be annoying, of course, but I covered my shelf with fabric curtains. It works great for me and keeps the dust out effectively.
A small tip: Just install curtain tracks from the hardware store and attach curtains with clips. It doesn’t cost much and looks pretty cool!
mo-hau
10 Aug 2021 10:52
rushahin,
regarding the dust accumulation on the Kallax shelf at your workbench, you basically have the following options:
1. Seal the compartments: Install plexiglass doors or custom-fit sliding panels as dust protection.
2. Surface sealing: A clear coat or laminate makes cleaning easier.
3. Dust extraction: Use tools with integrated dust extraction or portable vacuum units.
4. Regular cleaning: Removing coarse dust daily reduces dirt buildup.
In addition, you should try to minimize dust generation by moving work processes with high fine dust levels to dedicated workbenches or specific areas.
The Kallax lacks a dust-tight construction overall – it is furniture designed for living rooms, not workshops.
