ᐅ KALLAX does not fit under a sloped ceiling – is cutting it down an option?
Created on: 29 Nov 2023 10:17
Dragla
I have an IKEA KALLAX shelf that I would like to place under my sloped ceiling. Unfortunately, it does not fit at its standard height because the slope becomes quite steep at a certain point. My question is: Is it generally possible and advisable to cut the KALLAX shelf either at the bottom or top to better fit the slope? What practical experiences are there, especially regarding stability and appearance? And are there specific tools or techniques recommended to avoid damaging the furniture?
I would appreciate any tips, experiences, or advice on the best way to solve this issue without significantly reducing functionality.
GALEO4 schrieb:
Cut shelves often look unstable and cheap, and what about the appearance?I understand the concerns, but not everyone has the resources or time to have a piece of furniture completely rebuilt. Especially with KALLAX, I think the argument is valid that with good craftsmanship and some patience, you can achieve a clean result.
It is also important not to get discouraged if the first cut isn’t perfect. I appreciate when people look for solutions to make the best use of their space, even if it means doing some DIY work.
Maybe it also helps to attach some protective pads under the cut edge to improve stability. 🙂
Dragla schrieb:
Is it generally possible and practical to simply cut a KALLAX shelf unit from the top or bottom?Technically, it is possible, but I would recommend careful planning beforehand:
1. Measure the height accurately and determine exactly where the cut should be made.
2. Check the position of the reinforcements, as removing them can significantly reduce stability.
3. Use an appropriate saw with a guide (e.g., a table saw) for straight and precise cuts.
4. Seal the cut edge with edge banding or waterproof varnish.
In my experience, cutting from the top is better to maintain functionality, and cutting from the bottom should be avoided if possible, as the unit may no longer sit flat.
If you have no experience with sawing, I recommend consulting a carpenter or someone with a suitable workshop. This will lead to a much better result.
Cecilera662 Dec 2023 07:43Cutting is possible, but only with a cordless jigsaw or a miter saw. Afterwards, sand the edges and apply edge banding. Make sure to leave a stable base at the bottom end; otherwise, the shelf will be unstable.
Cecilera66 schrieb:
Cutting off is possible, but only with a cordless jigsaw or a miter saw.Additionally, I would like to point out that the cutting power of a cordless jigsaw is limited; if you feel noticeable resistance, it’s better to cut more slowly to avoid splintering.
Masking the cutting line with painter’s tape before cutting also helps minimize fraying. After cutting, I recommend using a fine rasp or sandpaper to smooth the edges.
If you are serious about cutting off parts, make sure that no cross braces are cut through, as this will completely compromise the structure’s stability.
Dragla schrieb:
Is it generally possible and sensible to simply saw off the bottom or top of a KALLAX shelf to optimally fit it to a sloped ceiling?I would like to revisit the question of whether this is a good idea: If a shelf is designed with a standard height, why would you want to significantly modify it on your own?
The issue of a sloped ceiling can be addressed in various ways—for example, with curved shelves, custom-built solutions, or flexible shelving options like the ones described by labar43.
My advice: Consider whether the effort and potential risks (loss of stability, appearance, warranty) are truly worth it compared to alternative solutions. If you still want to proceed, make sure to plan carefully and take appropriate precautions.
