ᐅ Kallax shelf unit no longer stable after rearranging sofa – why?
Created on: 16 May 2024 14:22
Sin36
Sin36
16 May 2024 14:22
I recently rearranged my Kallax shelf after moving the sofa from its previous position. Now it’s clear that the shelf isn’t as stable as before. It wobbles a bit and seems like it’s no longer properly aligned or secured.
Does anyone know why changing the furniture layout nearby might affect the stability of the Kallax? Could there be certain forces or support that were previously absorbed and are now missing? I haven’t added any extra weight, just changed its position.
I would appreciate any technical explanations or tips on how to fix this issue.
mauka
16 May 2024 14:47
Sin36 schrieb:
Does anyone know why changing the furniture nearby could affect the stability of the Kallax?
Great question and a classic example of “everything is connected”! 😄 Sometimes a sofa or another piece of furniture actually provides some support or prevents a shelf from tipping over easily. If you move the sofa, you might lose that “stabilizer.”
Also, the floor under the shelf may feel different where the shelf is now placed – it could be slightly sloped or uneven. A good tip: try using small felt pads or furniture shims underneath – that usually restores a lot of stability! 🙂
Surela
16 May 2024 15:13
mauka schrieb:
Sometimes a couch or another piece of furniture actually provides some support or prevents a shelf from tipping slightly.
That is already an excellent starting point. If I may add a small note: Kallax is designed as a modular shelving unit with back panels, which increase stability against twisting and tipping. Two things may have changed during the rearrangement that could make the shelf less stable.
First, the shelf might no longer be standing on a perfectly level surface. Wooden floors, tile joints, or carpets can cause wobbling if the base is not perfectly even. Second, an adjacent piece of furniture could previously have provided extra lateral support to prevent tipping, which is now missing.
Another point is the load distribution: Even without additional items, it looks like the load previously applied by your sofa (e.g., leaning) now has less stabilizing effect.
Could you please also let us know whether the shelf was fully loaded before the rearrangement and how it is equipped now? That would help provide more precise advice.
Sin36
16 May 2024 15:41
Surela schrieb:
Could you also please say whether the shelf was fully stocked before the rearrangement and how it is stocked now?
Thank you for asking! Yes, the shelf was fully stocked both before and after the rearrangement with the same items.
Previously, it was located in a corner, directly at the left side of the sofa, with no gap. Now it is about 30 cm (12 inches) away due to moving the sofa.
The floor is laminate, which should be laid on a fairly level surface. However, the sofa was previously against the wall and may have compensated for a slight wall unevenness.
I have not made any additional stabilization adjustments to the shelf, such as wedges or similar.
U
usbla
16 May 2024 16:03
First of all, furniture like the Kallax shelf is structurally designed to either fit into a niche or stand together with other furniture. By placing it directly against the sofa beforehand, the system gains lateral support. Removing this support makes the shelf rely more on the floor for stability.
Furthermore, small unevenness in the laminate flooring combined with the lack of lateral support can increase wobbling.
Technically, the instability often results from missing form fit (positive locking) at at least one point. I recommend equipping the shelf feet with adjustable furniture glides to optimize the contact with the floor. Alternatively, rear corner brackets can be used to additionally brace the shelf.
The 30cm (12 inches) gap from the couch also means there is no support from the furniture, making it easier for the shelf to twist. If necessary, place the shelf closer to the wall and check its vertical alignment with a spirit level.
lisku
16 May 2024 16:27
If there is any wobbling, first check whether all feet are evenly touching the floor.
Then use adjustable felt pads or shims.
Do not place the shelf freely in the room; position it against a wall or furniture.
