ᐅ Kallax unit no longer level due to uneven floorboards – ideas for leveling?
Created on: 4 Nov 2023 08:37
majolu
majolu
4 Nov 2023 08:37
I have a Kallax shelving unit that I placed on an old wooden plank floor. Unfortunately, the floor isn’t even – some of the planks are slightly warped and there are several uneven spots, causing the shelving unit to wobble sideways and not sit perfectly level.
The shelving unit is full of books and some decorative items, so stability is very important, and I also want to avoid damaging the unit.
Does anyone have experience or ideas on how to level or stabilize a Kallax shelving unit on an uneven wooden plank floor? I’m looking for practical solutions that don’t require major modifications but still provide a secure and level result.
Would a combination of pads, wedge-shaped shims, or special furniture feet be a good approach? I’d appreciate any well-considered advice!
Gloriagl10
4 Nov 2023 09:02
I would recommend placing small furniture wedges made of rubber or wood under the legs. They are easy to adjust and affordable.
RENMA
4 Nov 2023 10:46
To level a Kallax shelf unit on an uneven wooden floorboard surface, it is advisable to first measure the irregularities precisely using a spirit level or a long straightedge.
Next, adjustable furniture feet can be installed if the shelf does not already have them. These provide a reliable way to compensate for small differences in height.
If mounting on the furniture legs is not possible, wedge-shaped shim pads made of plastic or wood are a practical alternative. However, these must be cut precisely to ensure stability.
Additionally, a thin rubber mat as an underlay can help to cushion the unevenness somewhat without causing the shelf to tip or wobble.
Elias
4 Nov 2023 11:30
majolu schrieb:
The shelf is full of books and some decorative items, so stability is definitely important
That sounds really stressful if the shelf keeps wobbling. I had a similar issue myself on old floorboards. What helped me a lot was using small angle brackets on the shelf and height-adjustable feet. It’s important that the feet are firmly fixed and don’t give way, especially when the shelf holds many books.
I can also understand not wanting to put in too much effort. Maybe a combination of self-adhesive felt pads and rubber wedges could be practical, so the shelf stands securely at first and then you can do some fine-tuning.
Keep us updated on what you decide!
Joshbe
5 Nov 2023 07:25
RENMA schrieb:
adjustable furniture feet should be installed if the shelf does not already have them
In my opinion, this is the best solution. With Kallax shelves, the legs can be relatively easily replaced or added. Adjustable feet made of metal or plastic are simple to install and allow for precise, millimeter-accurate (inch-accurate) adjustment to uneven floors.
If the shelf is firmly attached to the back panel, it is advisable to temporarily loosen it in order to make the alignment.
Alternatively, I have also seen many people use small wedges made of wood or plastic, which are placed underneath and matched in color to the furniture or floor.
anken
5 Nov 2023 12:54
In case you haven’t considered this yet: before installation or adjustment, please check how severe the unevenness really is. Sometimes the issue is that the floor is slightly springy in some spots, especially with older wooden floorboards.
A useful approach is to stabilize the heaviest spots with small plywood sheets or firm underlays before leveling the shelf.
For safety, the shelf should still be checked regularly after leveling, as wooden floorboards can change over time – particularly with fluctuations in humidity.
A long-term solution could be to apply a thin leveling compound under the floor, but this would likely involve a more extensive intervention that you probably want to avoid.
