Today I assembled my new KALLAX shelf unit and noticed that the back panel appears to have been nailed in significantly too low, meaning the nails are positioned much further down than intended. I’m curious about the potential effects of this—specifically, could this have long-term impacts on the stability of the shelf, or might the material get damaged? Additionally, I’m wondering if the back panel might come loose or break more easily if the nails aren’t correctly placed. Has anyone experienced this exact issue or know if IKEA commonly delivers KALLAX units like this? I’d appreciate your insights!
I had a similar issue with my KALLAX. The nails weren’t placed ideally, so the back panel was loose at the bottom. For me, it was easy to fix with a bit of DIY skill: just pull the nails out slightly and reinsert them in the correct place. It wasn’t complicated and the shelf was much sturdier afterward. Maybe this could be an option for you?
In addition to what has already been mentioned, I would like to address the material quality: The back panels in KALLAX units are often not very thick and tend to be quite brittle. If nails are driven in too deep or not at the intended points, there is a higher risk of the material splintering or breaking. This can be improved by carefully adjusting the fastening—ideally using a small hammer and possibly support strips to avoid putting extra pressure on the back panel.
If you are unsure about performing any DIY modifications, it is advisable to use the warranty or contact the retailer. Damage usually occurs during assembly, and the back panel is not easy to replace if it has been damaged.
BeAndrea schrieb:
The back panels on KALLAX units are often not very thick and relatively brittle.Exactly, that’s why it’s important not to drive the nail in too deeply. Otherwise, it’s better to secure it with clamp screws or additional brackets rather than damage the back panel.
