Hello everyone, I have a somewhat unusual question about using the IKEA Kallax shelving unit as a shoe rack, especially in areas with increased moisture, such as hallways or basements. Since the Kallax is made of wood-based panels, I am curious about how well it resists moisture when storing shoes that might be wet or damp regularly—especially during winter or rainy weather. Can such a shelf hold up without the shelves swelling or mold developing? Are there any special protective measures or treatments that could make the Kallax better suited for this kind of use? I look forward to expert experiences or tips on how to “repurpose” the Kallax as a shoe rack without moisture damaging the material in the long term.
The main challenge when using Kallax as a shoe rack in damp conditions is the material type: Kallax is made of particleboard with a melamine coating, which can resist some moisture but does not provide long-term waterproofing. If the material is repeatedly exposed to moisture over an extended period—such as from wet shoes—the particleboard will swell and lose stability. Mold can also develop if moisture penetrates the material and does not dry out. For reliable use in damp areas, I recommend adding an extra protective layer, for example, placing waterproof mats on the shelves or treating the surface beforehand with a suitable wood preservative. Alternatively, shelves made of plastic or metal are better suited for damp environments.
I would like to add the following: Moisture generally causes problems with particleboard, as it swells and loses structural strength. For long-term use as a shoe rack, I recommend protecting the shelves with water-resistant mats or rubber sole liners to avoid direct exposure to moisture. Proper ventilation of the room is also important to allow moisture to escape quickly. A small dehumidifier can also be helpful. If you place the Kallax units outdoors or in very damp basements, the material will not withstand these conditions over time. If possible, shoes should be dried before placing them on the shelves. Regularly checking for any irregularities, such as warping of the shelves, is advisable.
Timmyse369 Feb 2021 18:42I can easily understand wanting to improvise with a Kallax shelf – I also use mine in the hallway to store shoes. 🙂 However, I eventually experienced that after some time, especially with wet winter shoes, the bottom panels began to swell slightly and the surface developed small bubbles. That was frustrating at first. What helped me was using a thin mat as a base and also making sure to wipe the shoes and let them air out for a short time before placing them. So, putting shoes that are dripping wet directly on the shelf doesn’t work well.
SUBEN60 schrieb:
The fundamental challenge when using Kallax as a shoe rack in damp conditions is the material propertiesFrom a technical perspective, this is absolutely correct. Additionally, it should be noted that the engineered wood used is not specifically designed for damp environments, so it does not comply with standards for moisture resistance (such as DIN EN 312). While there are particle boards with moisture protection, Kallax is not one of them. Prolonged exposure to water will therefore quickly cause deformation and material failure. Coating with moisture-repellent varnishes or sealants can improve protection but does not fully prevent moisture penetration. It is also important to note that the joints of the components, such as edges and screw holes, are particularly vulnerable and tend to allow moisture ingress.
