ᐅ The KALLAX unit is missing a base panel – should I buy a replacement?
Created on: 11 Oct 2020 09:37
Sulitan
Some time ago, I purchased the KALLAX shelving unit from IKEA and noticed during assembly that the base panel at the bottom is missing. According to the instructions, the base panel seems to be an important element for ensuring stability and protecting the unit from direct contact with the floor.
My question is: Is it worth buying a replacement part for this base panel directly from IKEA, or are there alternative solutions that are both stable and cost-effective? I want to avoid the shelving unit becoming unstable or sustaining damage from direct floor contact over time.
Has anyone experienced missing or damaged base panels with the KALLAX shelving unit? How did you solve the issue? Additionally, I am interested in whether the absence of the base panel can really lead to long-term problems.
Thanks in advance for your insights and recommendations!
naujon
12 Oct 2020 08:14
I would like to add that the base panel of the KALLAX shelf is not just a simple wooden board but often has a coating that protects the material from moisture.
If you are planning to purchase a replacement, you should consider the following points:
1. Check the exact model number of your KALLAX, as there are different versions with slightly different base panels.
2. Ordering replacement parts from IKEA is the safest option, although shipping can sometimes take several days.
3. Alternatively, you can buy suitable MDF or plywood panels of similar dimensions at a hardware store, but these should be well painted or treated.
4. If you are building a new unit yourself, consider sealing all edges and surfaces to prevent moisture damage.
Missing base panels can affect durability, so I recommend not cutting corners here. If you need flexible assistance, I’m happy to help you find the exact replacement.
elgla
12 Oct 2020 11:29
Sulitan schrieb:
Does anyone know if IKEA generally provides replacement base plates even when the plate isn’t damaged but simply missing?
I can understand how frustrating that is. You expect everything to arrive complete.
I had a similar situation with another IKEA shelving unit, and a small parts shipment was provided free of charge after I got in touch. The service was friendly and straightforward. I would recommend just giving it a try with a request—it can’t hurt 🙂 Sometimes it also helps to ask in person at a large IKEA store if you have one nearby.
Good luck, and I’m keeping my fingers crossed that it gets resolved quickly!
