ᐅ Installing KALLAX Under a Sloped Ceiling – How to Reinforce It?
Created on: 23 Dec 2020 08:47
FaploHello everyone, I recently installed a KALLAX shelf from IKEA under a sloped ceiling. Since the shelf had to be adjusted in height for this spot, it stands against the slanted wall, which presents some challenges regarding stability.
My question is: How can I effectively reinforce or stabilize the KALLAX shelf to ensure it remains secure and sturdy without having to completely rebuild it? I am mainly concerned about mechanical stability to prevent tipping or sideways movement, as I do not want to drill screws into the sloped ceiling.
Does anyone have advice on how to stabilize the shelf, for example with additional braces, angle brackets, or similar methods? Which materials or installation techniques work particularly well in this kind of special installation situation under a pitched ceiling?
Hello Faplo, first of all, thank you for the very clear and detailed description of your situation. The issue with installing a KALLAX unit under a sloped ceiling is indeed not straightforward, as the shelf is not originally designed for angled walls.
What you can definitely do is secure the unit to the side walls with brackets, assuming these walls are vertical. To prevent tipping, adding diagonal braces at the back is highly recommended. Thin metal profiles or wooden battens, which you attach diagonally against the back panel, work best.
Since you don’t want to drill into the sloped ceiling, I suggest using strong tension clamps or specially designed heavy-duty hook-and-loop systems to at least secure the unit against shifting. Make sure the materials you use can support the weight and do not cause damage. I hope this helps! If you have more details, I can gladly suggest specific products.
Hello Faplo, I’m happy to give you a structured answer on the topic "Installing KALLAX under a sloped ceiling – how to reinforce it?"
1. Main issue: The shelf is not level because of the slope, and it often cannot be secured to the wall on the side.
2. Fixing: If you don’t want to drill into the sloped wall, securing the back of the shelf is important.
3. Reinforcements:
- Get sturdy metal brackets or wooden battens that you can screw diagonally to the back of the shelf with cross braces.
- An additional leg or a small filler strip between the shelf base and the floor can greatly improve stability against tipping.
4. Materials:
- Use plywood battens, for example, as they are very strong and easy to work with.
- Avoid brackets that are too thin and may bend.
5. Installations without drilling into the slope:
- Clamping or tension solutions can help – for example, tension rods that you secure between floor and ceiling.
In summary: You increase stability through diagonal bracing, useful filler strips, and, if possible, securing to stable surfaces. If you like, I can create a drawing or a materials list for you.
3. Reinforcements:
4. Materials:
Ramon4 schrieb:
To prevent tipping, adding diagonal braces at the back is very effective.I can only agree with that; I had a similar problem. For me, it helped a lot to attach the braces inside the shelving unit with brackets and also to glue small rubber bumpers to the floor.
PAR63 schrieb:
If you want, I can create a drawing or a materials list for you.If you do, that would be really helpful! I was also concerned about stability, so those kinds of aids are invaluable.
A project like this is definitely challenging, but with the right reinforcement, it can be done! 🙂 Feel free to share how it goes for you if you like.
