I have a problem with my IKEA Kallax shelves: the inserts (such as the boxes, drawers, and clothes rod holders) tend to loosen quite quickly, which means they no longer fit tightly and securely. This makes handling much more difficult, and the entire shelf feels a bit “wobbly.”
I’m wondering: how can the loosening of the Kallax inserts be prevented or at least significantly slowed down? Are there any special tricks or materials that can help, or is this more of a design issue that’s hard to avoid?
I have already considered using rubber pads, stops, or other aids before looking into alternatives. I would appreciate any advice.
Kyler10 schrieb:
Use of self-adhesive rubber pads at the contact points Thanks, that sounds practical.
Are there any specific products or recommendations regarding the ideal size or material thickness? I don’t want to use something too thick so the inserts don’t get stuck, but also not too thin that it has no effect.
Giagau schrieb:
Small wooden strips or rubber pads on the support surfaces I will definitely try that. How do you usually attach them? Gluing or screwing?
I recommend thin neoprene foam pads. They are usually 1-2 millimeters (0.04-0.08 inches) thick and provide a lot of grip. Adhesive has worked well for me for years.
I would only use screws if drilling is possible and acceptable, not in rental apartments or similar situations.
Kallax inserts become loose? That sounds like my old jeans after too many trips through the dryer 😉
Jokes aside: Rubber bumpers are great, but I would also recommend regularly blowing out and cleaning everything. People often underestimate how dust and dirt on the rails or contact surfaces can increase the feeling of looseness. A bit of maintenance and careful handling is a real secret tip.
You can get small rubber bumpers for just a few euros at hardware stores, for example as furniture protectors. It’s worth trying and sticking with it.
A structured approach might help:
1. Remove inserts and clean all surfaces. Dust and dirt reduce performance more than you might expect.
2. Apply rubber bumpers (1-2 mm thick, self-adhesive) to the contact areas.
3. Reduce stress by distributing the load evenly.
4. If there is play or wobbling, fix short wooden strips (1 cm wide, cut to size) using double-sided tape.
5. Check regularly and make adjustments as needed.
Point 4 is often underestimated because people think changes are complicated. In fact, it requires minimal effort but has a significant impact.
RETRAVIS schrieb:
the original plastic connectors replaced by metal clipsYou are absolutely right, that would be the technically cleanest solution. However, I doubt many IKEA users prefer to go through that effort. Most stick with the simple IKEA system and just replace the entire unit if problems arise. The question is how much effort you are willing to invest in an inexpensive piece of furniture ;-)
