Some time ago, I painted a Kallax shelf to protect the wood a bit and improve its appearance. After painting, I now have the problem that some of the inserts (the small drawers or boxes) stick or can only be moved with a lot of force. I suspect that the paint layer slightly changed the dimensions and therefore affects the fit.
Can anyone advise me on the best way to adjust these Kallax inserts so they slide smoothly and don’t stick anymore? I would prefer not to just sand them, as I want to preserve the surface as much as possible, but if there’s no other option, I would appreciate tips on how to proceed.
Are there proven methods for modifying them without damaging the paint? Or would it be better to focus on the rail or another mechanism?
Thanks for your advice!
Pa_amar schrieb:
After painting, I now have the problem that some inserts are sticking or can only be moved with a lot of force.This issue typically arises due to the additional thickness of the paint layer on the contact surfaces. To make the inserts move smoothly again, I recommend first checking whether the sticking points are on the side walls or the guides.
You can gently roughen the sticking areas selectively using fine sandpaper (grit 220 to 320). Important: Only treat the spots where the insert actually sticks, and work carefully to avoid removing too much paint. Wipe off with a cloth after sanding.
If the sticking points are on the guide rails, it is advisable to apply a wax or silicone spray to the sliding surfaces. These lubricants do not damage the paint and help improve smooth movement.
Alternatively, you can lightly treat the bearing surfaces with a polishing pad and some car polish, which makes the paint slightly smoother. However, this also requires a delicate touch.
Dopoki schrieb:
You can gently scuff the clamping surfaces selectively using fine sandpaper (grit 220 to 320).A practical approach that I would like to add:
First, you should accurately identify where the insert is sticking – simply remove the insert and check by hand if any gaps are missing due to paint application. A thin felt strip or suitable paper might help to reveal the contact points.
If you decide to sand: be sure to use a sanding block to ensure an even surface—small, controlled movements against the edge are important to avoid removing too much material.
Besides sanding, you can also carefully work the edges on the inside with a small, sharp chisel or scraper. Be cautious not to damage the paint in other areas.
A fine abrasive pad can also help to dull the paint at contact points and reduce friction without completely removing the protective coating.
It’s worth considering the type of paint you have: thicker paints (e.g., acrylic paint) can make edge adjustments unnecessarily difficult. In that case, a slight, careful rework of the guide rails could be considered, for example with fine sandpaper on a narrow wooden stick, saving material without directly risking the painted surface on the inserts.
Pa_amar schrieb:
Are there proven methods for refinishing without damaging the paint?Surface paints are sensitive to mechanical treatment, so spot sanding with very fine grit is the best approach. I recommend the following steps:
1. Identify the exact spots where there is sticking or binding.
2. Lightly sand these areas once with sandpaper grit 320 or finer, very carefully, and check repeatedly.
3. Wipe the paint with a damp, lint-free cloth to remove sanding dust.
4. Optionally, apply a small amount of compatible clear coat polish to restore the protective film.
If you are working on an otherwise smooth surface, it is advisable to lightly polish the entire contact area, using polish or very fine abrasive pads.
Applying a dry silicone spray to sliding surfaces is a common recommendation. Be sure to verify that it is safe for use on paint.
Pa_amar schrieb:
I don’t just want to sand, as I want to preserve the surface as much as possibleThat’s understandable, but I would fundamentally ask: Is the paint application the real issue, or are the inserts and the shelf possibly already slightly warped or imprecisely manufactured? Sometimes Kallax inserts are not made to an accuracy of hundredths of a millimeter.
Beyond simple touch-ups, it could also be worthwhile to check whether the paint layer is actually affecting the key areas or if, for example, the guides themselves have been slightly warped by moisture or pressure.
Also: Was the paint applied to the entire internal dimension or only to the visible surfaces? Sometimes sticking occurs when paint that was sanded off unevenly is applied inside the cabinet’s internal dimensions. A measurement with a caliper might be useful here to accurately determine the extent of the dimensional change.
Seriously: Light sanding or lubrication may only treat symptoms, not the underlying cause.
