ᐅ Kallax units are always slightly uneven in older houses – is that a problem?
Created on: 21 Oct 2021 17:43
neixlu
Hello everyone, I bought a Kallax shelf and set it up in my old apartment. I noticed that, despite careful leveling, the shelf always stands slightly crooked. The floors and walls here are not really straight, which I’m familiar with in older buildings. My question is: Is it problematic if a Kallax shelf remains slightly tilted over time? Could this affect its stability or cause damage in the long run? I want to avoid the shelf tipping over eventually or the shelves warping. Maybe someone who knows about this type of furniture and the conditions in older buildings can give me advice on how to handle it best.
MUMENAR
22 Oct 2021 12:44
I would like to add something that hasn’t been addressed enough so far: How severe is the tilt exactly?
There is a wide range between "slightly tilted" and "clearly leaning."
If the shelf is positioned so unevenly that loads are distributed unevenly, the entire structural integrity suffers. This affects not only the shelf itself but potentially the stored items as well – they could slide or tip over.
Additionally, a lot depends on the location: In older apartments, floors are often made of wood, which can change with humidity. This could put extra strain on a leaning shelf.
Therefore, any inaccuracy should be compensated for as much as possible. Using wedges or an adjustable-height base could be a worthwhile investment. Wall mounting is advisable but does not fully replace having the shelf properly leveled.
gesar32
22 Oct 2021 14:10
From a purely technical perspective: Kallax is usually made of particleboard with a melamine coating. These panels are sturdy but can be vulnerable to stress from constant tension or pressure at unfavorable angles.
If the shelf is permanently leaning, the material at the joints (e.g., screws, dowels) can become overstressed. Over time, this may cause looseness or even cracks.
Recommendation: Use a spirit level for accurate measurement and, if necessary, level the floor with appropriate shims. It is important that the connection to the wall and floor is as perpendicular as possible to prevent material damage.
LEEJU
22 Oct 2021 15:55
In short: A slight tilt does not cause immediate harm, but the structure must be stable. Wall mounting combined with small shims or wedges, if necessary, is the best solution. This way, you will enjoy it for a long time.
GLALEO
22 Oct 2021 17:23
NEIXLU schrieb:
I want to avoid the shelf tipping over or the shelves warping over time.
Great approach! 🙂 I had the same issue and quickly leveled the shelf with a few homemade wooden shims. After that, I secured it to the wall—and since then, it’s been rock solid, looks great, and there’s been no more warping.
Kallax is very versatile but can be sensitive to heavy loads. A little effort goes a long way, and the stability improves immediately.
neixlu
23 Oct 2021 10:01
Thank you very much for the many informative responses! I found TAUPLO’s advice on wall mounting and the tips about furniture shims especially helpful. The tilt is actually quite slight (estimated about 2-3 degrees). I will first try to level it using shims and then add a bracket. This should effectively minimize the risk of damage and tipping. If any issues arise later, I will get back to you. Thanks again to everyone!
