ᐅ After transportation, the Kallax has become noticeably less stable – is there a way to reinforce or stabilize it?
Created on: 26 Nov 2023 18:23
Duge32
Duge32
26 Nov 2023 18:23
I recently ordered a Kallax shelving unit from Ikea and transported it home. I noticed that after the transport, the shelf has become noticeably less stable than before shipping. Specifically, it wobbles more and feels less solid. While it is still functional, I definitely miss the feeling of stability.
I’m wondering if this is a common issue with Kallax shelves or if the transport actually caused damage that can be repaired. Has anyone had experience with stabilizing the shelf after transport? Are there effective solutions like adding extra screws, reinforcements, or other tricks?
I appreciate any practical advice or tips on possible damage I should check for. Thanks in advance!
fiman
26 Nov 2023 19:07
I am familiar with the problem of instability after transport. Usually, it is enough to re-screw the entire shelf, especially the back panel. Sometimes screws or nails come loose there.
If no back panel has been installed yet, be sure to add one. This provides a lot of stability.
Nathanaelk
27 Nov 2023 09:56
Hello Duge32,
First of all: The Kallax shelf is not designed for heavy mechanical loads or frequent transportation. Its construction consists of medium-density fiberboard (MDF) and painted particleboard, combined with edge banding. During transportation, joints can loosen or the back panel can shift – this results in noticeable instability.
To fix this, I would recommend the following step-by-step approach:
1. Check and secure the back panel: The back panel provides lateral stability. Make sure it is still properly in place and that all nails or screws are firmly fixed. If not, re-nail or insert small screws.
2. Inspect connection hardware: Ikea mainly uses metal cam locks and dowels for Kallax. These can come loose due to vibrations. Completely loosening and retightening them often helps.
3. Additional reinforcements: If the original connections are not sufficient or no longer hold, you can add metal brackets in the corners, which are hardly visible from the inside. This significantly improves stability.
4. Secure the base: Sometimes small felt pads under the feet help to compensate for slight unevenness.
It would be helpful to know exactly how the shelf was transported. Was it fully assembled or disassembled? And have you moved or carried the Kallax anywhere after the transport?
If you have pictures (or even just descriptions) showing how wobbly it is or if any connections appear damaged, we can provide more precise help.
In summary: A combination of a properly mounted back panel, secure connections, and possibly added brackets or screws are the steps to resolve the issue. The shelf is simple in design, but stability strongly depends on these factors.
roryvin
27 Nov 2023 13:42
Nathanaelk schrieb:
The Kallax shelf unit is basically not designed for heavy mechanical stress or frequent moving.
I can only agree with that. Kallax is designed as a stationary piece of furniture and optimized for stable placement during normal use, not for frequent relocation.
A small addition: also check if the base of your Kallax is uneven or slippery, as wobbling is often caused by uneven contact surfaces. In this case, small non-slip rubber pads or felt glides are recommended to help secure the furniture somewhat.
Additionally, you can try reinforcing the shelf with a back panel that has strengthened metal braces, or even use a plywood panel if the original parts are no longer sufficient. This significantly increases the torsional rigidity.
Clear recommendations:
- Readjust all connections
- Inspect and, if necessary, replace or reinforce the back panel
- Level or improve the base support
These measures will stabilize the shelf well enough for normal use again.
Elodie
28 Nov 2023 08:15
Duge32 schrieb:
Does anyone have experience with how to stabilize a shelf after it has been transported? Are there effective methods like adding extra screws, reinforcements, or other tricks?
Hey, I know this all too well! After a move or transport, my Kallax shelf always feels like it’s ready to start a ‘wobbly dog contest’ ;-)
I’ve had good results when I completely take it apart and then reassemble it. Here’s what I usually do:
- Add extra metal brackets on the inside corners (they’re very affordable and make a big difference)
- Secure the back panel with stronger screws instead of just nails
- If possible, attach small brackets or strips at the back in exposed areas
It might sound like a lot of effort at first, but it’s worth it. 🙂 I find it makes the furniture really sturdy again—like new! Check if you already have some screws and brackets lying around, so it won’t cost extra.
Sometimes, just a bit of care and patience tightening the screws helps too ;-) Good luck!
