I noticed that one of the mounting brackets is missing from my new Kallax shelf unit. Specifically, it’s the small metal clip used to secure or stabilize the shelf to the wall. Since I need to assemble the shelf urgently and don’t have time to wait for a replacement, I’m wondering how I can improvise.
What simple and safe solutions do you know to replace a missing Kallax bracket? Are there alternatives that are stable enough without using specialized parts? I want to make sure the shelf is securely anchored to prevent tipping, without scratching or damaging it.
I look forward to your ideas and experiences!
LOGEMIN schrieb:
this is not a perfect 1:1 replica of the IKEA part, but a solid and reliable solutionThank you for the detailed instructions; that sounds like the most sensible approach. Do you have any advice on which screw size and type of anchor work best for drywall? I want to avoid the mounting coming loose later on.
Kakarin schrieb:
which screw size and type of anchor is particularly suitable when the wall is made of drywallFor drywall walls, I recommend cavity anchors that are specifically designed for drywall (also known as toggle anchors). Screws sized 4 x 40 mm (approx. 5/32 x 1 9/16 inches) work well, as they provide enough support without damaging the drywall.
Make sure to observe the maximum load capacity of the anchors and position the mounts accordingly so that the weight is well distributed.
I know this problem! When I installed the shelf for the first time, I also mounted it on the wall without the original hanger, using extra strong brackets from my hardware store. It is important to attach it only to solid points such as door frames or load-bearing walls.
If you live in a rental apartment, which I assume has drywall, you should also check with the landlord whether mounting is allowed, otherwise you may face troublesome questions when moving out.
Elias schrieb:
If you live in a rented apartment, which I assume you do with drywall, you should also ask the landlord if mounting is allowedThanks for the advice, I have already clarified that. According to the landlord, it is permitted, but only with anchors that do not create large holes. Therefore, I will try the toggle anchors you recommended.
Does anyone else have any safety-related tips for attaching the Kallax to drywall?
Sure, here is a brief overview:
1. Use toggle anchors – they expand behind the drywall and provide strong support.
2. Screws 4x40 mm (approximately 1/6 x 1 5/8 inches) or similar, matching the anchor size.
3. The shelf should always be supported with at least two fixing points.
4. After installation, check stability by gently pulling the shelf.
Important: The fixing points should ideally be placed on a reinforcement (e.g., a wooden batten behind the drywall), if available.
This helps effectively prevent injuries caused by tipping.
