ᐅ Kallax hanger missing – how to improvise?
Created on: 31 Jan 2024 08:23
Kakarin
Kakarin
31 Jan 2024 08:23
I noticed that one of the mounting brackets is missing from my new Kallax shelf unit. Specifically, it’s the small metal clip used to secure or stabilize the shelf to the wall. Since I need to assemble the shelf urgently and don’t have time to wait for a replacement, I’m wondering how I can improvise.
What simple and safe solutions do you know to replace a missing Kallax bracket? Are there alternatives that are stable enough without using specialized parts? I want to make sure the shelf is securely anchored to prevent tipping, without scratching or damaging it.
I look forward to your ideas and experiences!
peovin
31 Jan 2024 08:41
Just get small brackets from the hardware store, attach them directly to the Kallax with screws, and fix it to the wall. This holds well and is quick to do.
pa-wolf
31 Jan 2024 09:05
I would avoid tape solutions. It is better to use sturdy metal brackets or L-shaped holders that can be mounted on the wall. This provides stability and safety.
LOGEMIN
31 Jan 2024 09:34
Hello Kakarin,
If the original hanger is missing, you can proceed as follows:
1. Obtain materials: Small metal brackets (2-3 cm (1-1¼ inches) wide) and suitable wood screws
2. Determine the position: On the top back of the Kallax unit, where the hanger is usually located
3. Attach: Use one or two screws per bracket, making sure the bracket does not protrude into the shelf interior
4. Wall mounting: Use appropriate wall plugs and screws for your wall to ensure everything is securely fixed and stable
Important: The screws should be short enough not to go through the entire shelf, but still hold firmly.
This is not a perfect 1:1 replica of the IKEA part, but a solid and secure solution.
loken
31 Jan 2024 10:02
Hey Kakarin, I tried this with small cable tensioners – basically a mini guy-line setup on the wall, which holds the Kallax perfectly in place without needing much drilling. It even looks quite cool 😉 You can use colorful straps to make it almost a visual highlight!
narDietmar
31 Jan 2024 10:49
The primary purpose of the hanger is to secure the shelf and prevent it from tipping over. If the original hanger is missing, the alternative should serve the same function; otherwise, there is a risk of injury.
A good option is to install metal brackets, as mentioned earlier. Make sure the shelf is positioned as close to the wall as possible and that the brackets are mounted to withstand pulling forces.
If you do not want to attach the shelf permanently to the wall, an anti-tip safety strap can be an alternative. This strap is fixed to screws in the wall and the shelf and is often also available as a child safety device.
