ᐅ Kallax Filled with Water After Using a Wet-Dry Vacuum in the Basement – Still Safe?
Created on: 30 Nov 2020 18:47
Leikron46L
Leikron4630 Nov 2020 18:47Hello everyone, I have a question regarding my Kallax shelves in the basement. Recently, I used a pressure washer to thoroughly clean the basement floor. During this process, water seems to have gotten into the shelves, causing the Kallax units to be partially soaked and swollen in some areas. My question is: After such exposure to water from a pressure washer, is the material of the Kallax shelves still safe in terms of stability and usability?
I am especially interested in whether the core boards have been damaged by the moisture, if any harmful substances could be released, or if the furniture might even pose a safety risk due to the moisture (for example, through instability or warping).
Does anyone have experience using a pressure washer in a basement directly on Kallax shelves or similar materials? How should the shelving unit be assessed in the long term after this? Are there any tips for rescuing the material, or would it be better to replace the shelf?
Thank you in advance for your assessments!
sarGabriel30 Nov 2020 19:03If the piece of furniture remains soft or becomes significantly deformed after absorbing water, it is no longer safe. Kallax is made of particleboard with melamine resin; when exposed to water, it swells and loses strength.
Drying can help, but the material often remains weakened. Therefore, it is better to replace it if it is heavily soaked.
sarGabriel schrieb:
Kallax consists of particleboard with melamine resin; it swells and loses strength when exposed to water.That is absolutely correct and important to know. To add: Kallax shelves mainly use medium-density fiberboard (MDF) or particleboard with a melamine resin coating, which is water-resistant but cannot withstand prolonged exposure to moisture.
When using high-pressure cleaners—which often involve a lot of water under high pressure—water can penetrate the edges or small gaps in the material. This causes the wood fibers to swell, resulting in lost strength and partial breakdown of the adhesive bonds within the boards.
Over time, this leads to significantly reduced load-bearing capacity. Especially critical are areas under load, as well as joints and edges.
From a safety perspective, this means:
1. Visual inspection: Are there visible bubbles, warping, or lifting surfaces?
2. Load test: Does the shelf remain stable under normal load or does it wobble?
3. Drying phase: Shelves should be thoroughly dried, preferably in heated, as dry as possible rooms. However, the material does not fully recover.
Harmful substances are unlikely to be released from the boards in dangerous amounts, but prolonged moisture can encourage mold growth, which can affect indoor air quality.
Conclusion: If shelves show noticeable warping or swelling, I recommend replacing them. Attempts to “rescue” the shelves involve complete drying in warm air, but this cannot restore structural stability.
Leikron46 schrieb:
I’m mainly interested in whether the carrier boards have been damaged by moisture, if any harmful substances could be released, or if the piece of furniture might even pose a safety risk due to the moisture (for example, from instability or warping).Here is a brief guide on how to assess and potentially salvage your Kallax shelves yourself after water damage caused by a high-pressure extractor.
1. Completely empty the shelves: Remove all items and blot any light moisture with an absorbent cloth.
2. Visual and tactile inspection: Look for deformations and soft spots. Press gently on the side panels. If they give way, the material is weakened.
3. Drying: Place the shelves in a warm, well-ventilated area, preferably with air circulation. A fan and a heater can significantly speed up drying. Avoid direct sunlight or strong heat.
4. Additional support: Temporarily reinforce with brackets or other fasteners if the shelf needs to be used while still damp.
5. Long-term check: After at least 2 weeks of drying, inspect again. Bubbles, cracks, or permanent deformation indicate irreparable damage.
6. Mold prevention: Check the interior surfaces. Moisture can promote mold growth, especially if there is no air exchange.
In many cases, proper drying can save much of the shelf. However, if the boards have swollen, the load-bearing capacity will likely be permanently compromised. In that case, it’s better to replace the shelving unit to avoid the risk of instability.
