ᐅ KALLAX from IKEA – Is It Worth Repairing or Better to Buy New?
Created on: 5 Oct 2023 18:22
LeonsauHello everyone,
I have been using a KALLAX shelf from IKEA for several years now, and I really like its storage capacity. However, recently some of the joints have become quite loose, and the surface has started to peel off at one corner. Now I’m wondering whether it makes more sense to try repairing these issues myself or having them professionally fixed, or if it would be better to just buy a new KALLAX.
I’m especially interested in the cost-effectiveness of repair versus replacement, whether IKEA offers spare parts, and of course how long a typical repair lasts compared to buying new. Has anyone here had experience repairing a KALLAX or any advice on when repair is worthwhile?
Thanks in advance for your input!
Leonsau schrieb:
whether, considering these damages, it makes more sense to undertake such repairs yourself or have them done professionally, or if it’s better to simply buy a new KALLAX.Basically, the KALLAX shelf is priced so that buying new can often be more economical than extensive repairs. IKEA does not officially offer replacement parts for individual connectors or panels. Therefore, you either have to improvise with generic screws, wood glue, or metal brackets, which may only temporarily restore stability.
Leonsau schrieb:
how the cost-performance ratio compares between repair and replacementWith multiple damaged areas, the cost of materials and the time required can quickly exceed the value of a new shelf. Buying new also ensures a full warranty, while repairs always carry some risk of further damage.
If the damage is minor and localized, a targeted repair with suitable connectors can be worthwhile. For extensive damage, buying new usually makes more sense.
Siflo schrieb:
IKEA does not officially offer spare parts for individual connectors or panels.This is partly true, but I have actually received spare parts for KALLAX from IKEA – at least screws and small components like dowels – if you ask nicely and provide the purchase receipt.
For repairs, it is important to first precisely locate the damaged connection points. Often, these are recessed dowels or cam lock connectors that wear out over time. You can get replacement parts by contacting customer support, which is usually accommodating.
If panels are damaged (e.g., roughened or broken off), you can repair them nicely with wood filler and then treat them with appropriate paint or varnish – however, this is mainly a cosmetic repair and does little to improve stability.
For serious stability issues, I recommend reinforcing the worn connection points from the inside with metal brackets. These need to fit well; otherwise, they could weaken the wood.
Leonsau schrieb:
how long a repair typically lasts compared to buying newWith careful work, I find repairs to be realistically durable for 3–5 years, depending on the load and usage. So I would suggest trying a localized repair first before fully replacing. If looseness reoccurs multiple times, purchasing a new unit is usually the cleaner solution.
Leonsau schrieb:
I am mainly interested in how the cost-effectiveness compares between repair and replacement.I can relate to your situation well – some time ago, I also had a KALLAX that lost stability after a few years. I decided against buying a new one because the shelf holds many memories, and instead tried to reinforce the connection points.
With some patience, a few metal brackets from the hardware store, and wood glue, I was able to restore the piece nicely. It now feels stable again, even though the shelf naturally shows some signs of use.
Depending on the emotional value and the location of use, I would recommend trying a low-cost repair first. If the shelf is subjected to heavy daily loads (e.g., storage for heavy books or equipment), you can reinforce the repair accordingly or replace it later.
Sometimes, the experience of “saving” something is also valuable and helps conserve resources. 🙂
