I recently moved and had to disassemble and reassemble my IKEA KALLAX shelving unit. Unfortunately, I noticed that the frame has lost stability due to being taken apart and put back together multiple times and now feels quite worn out. The joints are no longer as tight as before, and the whole thing feels rather wobbly. My question is: In such a case, should I really replace the entire frame to regain a stable structure, or are there effective repair or reinforcement methods to make a KALLAX frame sturdy again for the long term? I’m open to any suggestions, as I don’t want to buy a completely new unit unless absolutely necessary. Thanks in advance for your advice and tips!
GIIVAN35 schrieb:
Is medium-strength wood glue sufficient here, or would you recommend epoxy resin?For furniture made from particleboard, wood glue designed for engineered wood products is recommended. Medium-strength glue is often sufficient, as long as the parts remain secured with screws. Epoxy resin is indeed stronger, but it can reduce the material’s flexibility and is more difficult to work with.
Ethan schrieb:
stabilizing the connection holes, for example with wooden plugs or dowelsUsing wooden dowels has proven effective and is one of the best repair options for KALLAX to fix worn-out holes. There are also ready-made repair kits available for furniture repairs – including drill bits, dowels, and glue in one package.
In summary: wood glue plus wooden dowels, along with new screws and, if necessary, angle brackets, should restore the shelf’s stability without needing to replace everything.
NoValentin8 Feb 2022 11:16Replacing the entire frame only makes sense if the material is damaged or warped. Otherwise, tightening screws and adding reinforcements is completely sufficient.
GIIVAN35 schrieb:
I want to avoid the shelf becoming wobbly again after a short timeThe issue with KALLAX is often the material itself: particleboard is less sturdy than solid wood. If you frequently disassemble and reassemble the shelf, wobbly joints are likely to occur. Reinforcing with dowels and angle brackets significantly reduces this risk, but for long-lasting stability, strong furniture joints and careful assembly are essential.
Lis53 schrieb:
Wood glue plus wooden dowels, along with new screws and possibly angle bracketsA very good combination to get your shelf sturdy again. Good luck!
