ᐅ Kallax discolored after sun exposure – how to restore the surface?
Created on: 16 Jun 2020 18:26
gunu58
I left my Kallax shelf in the sun for several weeks to place some plants on it. Unfortunately, the surface of the shelf has faded significantly—almost white in some sun-exposed areas. My question is: How can I restore or at least visually improve this faded surface without repainting the entire shelf? Are there methods to balance or mask the fading without changing the original look too much?
Thanks for your tips and experiences!
gauvin37
16 Jun 2020 19:33
I also have a Kallax. When the finish is not clear-coated, sanding can cause a lot of damage. Try using a furniture touch-up marker in a matching color. That’s how I fix small blemishes; it looks fine.
gunu58
16 Jun 2020 20:02
BAUEVA schrieb:
It is important to know the exact material structure: Kallax shelves are usually made of melamine-coated particleboard, not a solid wood construction.
Thanks for the information. I wasn’t aware of that.
Landontau schrieb:
Use a special furniture pen or marker that matches the color of your Kallax.
Are there specific brands or products you would recommend? I want to make the repairs as inconspicuous as possible.
GAGRAHAM suggested stain, so it seems that wouldn’t be suitable if it’s melamine-coated.
GAGRAHAM
16 Jun 2020 20:10
gunu58 schrieb:
GAGRAHAM suggested stain, so that doesn’t seem suitable if it’s melamine-coated.
Oh, right, that was unclear on my part! I was actually thinking of similar wooden shelves. Melamine is not real wood, as I said; I should have been more precise. Sorry!
In that case, I would try using furniture dowels – they are also available in IKEA tag colors or neutral shades. 🙂
Elodie
16 Jun 2020 21:37
My tip: If you don’t want to completely repaint, try using a satin-matte synthetic resin paint suitable for melamine.
Lightly sand the area beforehand (400 grit – very fine!). Don’t worry, if you’re careful it won’t cause damage – the paint just needs something to adhere to.
This won’t lighten the surface by itself, but a new fresh coat can mask fading and will look much better afterwards. Plus, it offers protection against further damage! 😉
TELAHAU
17 Jun 2020 08:19
Just a quick note: furniture dowels are great, but only suitable for small areas. For larger surfaces, it’s better to use paint or veneer.
There are even self-adhesive veneers with wood patterns – they replace the surface, look good, and are affordable.
gunu58
17 Jun 2020 09:05
TELAHAU schrieb:
There are even self-adhesive films available in wood design – they replace the surface, look good, and are inexpensive.
Interesting, I hadn’t considered that at all. Does anyone have experience with this? How durable is such a film with frequent use, for example, if I regularly place plants on it? Can the moisture from the soil and watering damage the film?
