I noticed that the edges of the shelves and side panels of my IKEA Kallax unit have become visibly worn down due to frequent cleaning. This is the typical Kallax with the melamine-coated surface. My question is: Is this a common material issue with Kallax, where the edges are more prone to wear from cleaning products and wiping, or am I possibly doing something wrong when maintaining it?
I usually clean it with a damp microfiber cloth and a mild all-purpose cleaner. Still, the edges in some spots seem a bit rougher, and the color/coating is slightly peeling off.
What cleaning methods do you use to prevent this kind of wear? Are there any special care products or techniques that have proven effective over time?
I’m looking forward to your experiences and tips, especially if this problem is known or if I might have just gotten a defective piece. Thanks!
The material of Kallax is made of particleboard with a melamine coating, which is particularly vulnerable to mechanical stress on the edges. Frequent rubbing and the use of cleaning agents with aggressive ingredients can damage the protective layer.
For cleaning, a slightly damp cloth without cleaning agents is usually sufficient. For tougher stains, a pH-neutral cleaner is recommended. IKEA’s guidelines explicitly advise against using abrasive cleaners or solvents.
To prevent damage, it is also important to thoroughly dry the edges after cleaning, as constant moisture can soften the coating. Some users additionally protect the edges with transparent edge guards or furniture wax.
The issue of abrasion on the edges of Kallax furniture is actually a bit more complex, so I’ll try to provide a detailed analysis here:
About the material: Kallax is made from compressed wood fiberboard (particleboard) with a melamine resin coating. This coating provides a hard but relatively thin protective surface. Especially on the edges, the melamine layer is only applied on the side and is therefore less mechanically protected than the larger surfaces.
Frequent cleaning, particularly with damp cloths combined with cleaning agents that contain solvents or abrasives, can compromise the bond of the melamine resin layer. As a result, the edge loses its smooth surface and becomes rough, which can cause color abrasion.
Preventive measures:
1. Cleaning frequency: Avoid cleaning the edges too often; clean only when visible spots appear.
2. Cleaning agents: Use only mild, pH-neutral cleaners, preferably without chemical additives.
3. Cleaning technique: Wipe gently and dry immediately.
4. Edge protection: Use transparent plastic profiles or felt pads to reduce mechanical impact.
If abrasion has already progressed, you can gently smooth the rough spots with very fine sandpaper (e.g., 400 grit) and, if needed, touch up with special melamine or furniture edge protection lacquer available at hardware stores.
Therefore, my question to Sau_nu: Do you perhaps use other cleaning tools or cleaning agents than described? How often do you roughly clean the edges?
Domau0 schrieb:
So my question to Sau_nu: Do you perhaps use any other cleaning tools or products than the ones described? How often do you clean the edges approximately?Thank you for the detailed response. Yes, I usually just use a damp microfiber cloth with a mild, common all-purpose cleaner about once a week. No abrasives or any stronger substances.
Maybe I do dampen the cloth a bit too much—that was a good tip to dry the edges after wiping. I suppose that can happen, especially in the hard-to-reach areas.
Do you have experience whether applying a furniture wax treatment really improves the protection of the edges, or is it more of a cosmetic measure?
The issue with worn edges on Kallax furniture is related to the combination of material properties and cleaning routines.
Melamine coatings are generally durable but offer less protection at the joints – meaning the edges – where often only the raw particle board or edge banding is visible. Moisture can penetrate these areas and loosen the adhesive beneath the surface. Therefore, many experts recommend:
1. Avoid moisture: Always wipe dry immediately after cleaning.
2. Do not use abrasive cleaners or sponges.
3. If necessary, seal the edges with a special edge protection varnish or hard wax.
Applying furniture wax yourself can help, as it creates a slight water-repellent layer. However, it is important that the wax is compatible with melamine and does not become sticky or shiny, which could attract more dirt.
Additionally, the surface should be clean and dry before applying. Some users also swear by special edge protection profiles made of clear plastic that are glued onto the edges – although this alters the appearance, it provides lasting protection.
Finally, my question: Are the affected edges heavily subjected to mechanical stress (e.g. doors opened frequently, objects bumping into them), or is the wear mainly due to the cleaning?
