ᐅ KALLAX Edges Are Peeling – How to Glue Them Back?
Created on: 16 Feb 2021 08:27
duccio1
duccio1
16 Feb 2021 08:27
Hello everyone, I have noticed that the plastic coating on some edges of my Ikea KALLAX shelf is peeling off. This mainly happens on the outer edges of the shelves and not only looks unattractive but also causes faster wear. I am therefore interested in knowing which glue or method is best to securely and permanently reattach these edges. It is important to me that the adhesive is transparent and durable over time since the shelf is located in a frequently used living room and needs to withstand some wear and tear. Does anyone have practical experience or recommendations on products or methods that have proven effective? Thank you in advance for your help!
BEMAU
16 Feb 2021 09:42
As a general recommendation for KALLAX edges, a solution using a cyanoacrylate-based instant adhesive (e.g., instant glue) is advisable, as it cures very quickly and remains transparent. It is important to clean the surface thoroughly beforehand, removing dust or grease, preferably with isopropanol. Then, apply the adhesive sparingly along the separating edge and press the edge firmly for 30 seconds. This ensures a lasting bond. For larger areas, contact adhesive can also be used, but its application is significantly more complex.
kibutar
16 Feb 2021 11:05
I would like to explain the material and technique in more detail. The edges of KALLAX are usually made of melamine resin or plastic foil applied to particleboard – a composite that does not always respond optimally to mechanical stress. When gluing, it is important not only to have a clean, rough surface but also to use an adhesive that remains flexible to compensate for stresses caused by slight movements.
For this reason, I would recommend using PU (polyurethane) adhesive, which has a somewhat longer curing time but remains elastic and adheres very well to plastic. Epoxy adhesive is also an option, but it is usually too rigid and not necessary for household use.
Are you sure that the edges are completely peeling off, or is it only small areas? This affects the choice of adhesive as well as whether more surface preparation is needed. Please feel free to provide more details about the exact condition!
duccio1
16 Feb 2021 11:48
kibutar schrieb:
Are you sure that the edges are fully lifting, or are there just small areas?
Thanks for asking. It’s mostly small areas; about 1–2 cm (approximately 0.4–0.8 inches) come loose at several edges. The material itself is still intact; it’s the outer plastic film that’s peeling at the edge. So, I would prefer to work as minimally invasive as possible. If super glue works for this, that would be perfect. The idea of using PU adhesive sounds interesting, but do you have any product recommendations or application tips?
Also, I’m concerned that if too much adhesive is applied, it might be visibly noticeable later. That’s why I’m really looking for an adhesive that is transparent and needs to be applied only in a very thin layer.
Wyatt
16 Feb 2021 13:30
Regarding gluing KALLAX edges, it is crucial to use the right tools and an appropriate technique. Besides choosing the adhesive, the preparation step often plays a more important role in the success.
Here is my suggestion:
1. Lightly sand the edges with fine sandpaper (grit 120) to reduce adhesion problems caused by smooth plastic surfaces.
2. Degrease the surface with a lint-free cloth and isopropanol.
3. Use a thin, liquid CA adhesive (super glue). This material penetrates small gaps well, cures quickly, and is transparent.
4. Apply the glue sparingly, not too much – this prevents excess adhesive from oozing out.
5. Press the edges lightly with a clamp for about 30–60 seconds.
I have one question: Will the shelf be subject to high mechanical stress, for example as a seat or heavily loaded? This could affect the choice of adhesive.
NUPIN
16 Feb 2021 14:55
Oh, I know that feeling! I had the same huge frustration with my KALLAX! 🙂 Back then, I used a special plastic adhesive from Pattex – the "Pattex Plastic Special." It’s really great because it’s specifically designed for plastics and leaves almost no residue. Important: don’t apply too much, or you’ll see glue marks later on.
I also wiped the edges beforehand with a paper towel and let them dry. Then apply the glue, press firmly, and wait a few minutes.
It held perfectly for me and still looks almost brand new! Definitely a relief, highly recommend it! Good luck! 🙂
