ᐅ Kallax Dried After Water Damage – Is Its Load-Bearing Capacity Still Intact?
Created on: 28 Aug 2020 19:34
Sarbla41
Hello everyone, I have a question that’s been on my mind lately: I own a Kallax shelf unit from IKEA that was recently affected by water damage. The shelves and side panels were thoroughly dried after brief contact with water, but now I’m wondering if the load-bearing capacity of the furniture is still reliable. Can anyone share experience or expertise on whether a dried Kallax shelf can still handle everyday use just as well, or if the structural integrity may have been permanently compromised by the water? I understand that the shelf is made of coated fiberboard, but I’m curious about how durable this material really is after such damage. Thank you in advance for your assessments and advice!
Sarbla41
30 Aug 2020 18:07
Thanks for the many tips, they are very helpful!
I will inspect the back panel more closely over the next few days and may get a replacement board to make the shelf more stable again. The shelves themselves now feel dry and quite firm. Load tests with moderate weights are currently running without issues.
I still have a few questions:
1. In case of water damage on the edges, would applying wood glue or wood filler be recommended to stabilize the surfaces?
2. How long should an MDF shelf ideally be left to rest and dry after getting wet before it is fully loaded again?
I want to avoid mold growth or further material deterioration, as the shelf is located in our living area.
Marlenepa
30 Aug 2020 18:36
Sarbla41 schrieb:
Could using wood glue or wood filler on edges damaged by water exposure help stabilize the surfaces?
Hello, yes, that definitely makes sense. Wood glue can bond the fibers together and improve stability, especially if the surface is only slightly swollen. Wood filler is suitable for repairs on broken or heavily damaged areas.
Sarbla41 schrieb:
How long should an MDF shelf that has gotten wet ideally be left to rest and dry before it is fully loaded again?
It depends on the humidity and ventilation. With good airflow and room temperature, you should allow at least 72 hours, preferably 5–7 days to be sure that no residual moisture remains in the material. For higher loads, it’s better to allow more time.
Preventing mold is important, so either keep the environment dry and warm or ensure proper ventilation. In very humid rooms or if uncertain, a surface hygrometer can be helpful.
Good luck!
LAYNE
30 Aug 2020 18:58
Sarbla41 schrieb:
I want to avoid mold growth or further deterioration of the material
Absolutely, that’s something you definitely want to avoid! If it stayed dry for a while and the full weight wasn’t on it yet, you’ve already done a lot right. Wood glue works well if you want to fix small damages, and the longer you wait before applying it, the better. But don’t overdo it with holding it tightly—some wood needs to breathe.
Don’t stress too much; a Kallax actually handles water surprisingly well, as long as you don’t leave it soaking for hours. And if you reinforce the back panel, you’re in good shape. :-)
JONKO
31 Aug 2020 09:10
Just to emphasize once again: I really appreciate how carefully you’re handling this! Many people might just keep loading the shelf and hope for the best.
With a bit of patience and maintenance, the shelf will definitely continue to serve you well. As recommended, I would reinforce the back panel since that is the weak point. And some simple repairs like that also help clear your mind.
Wishing you continued success!
