ᐅ KALLAX drawers are crooked – what could be the cause?
Created on: 24 Jul 2021 09:18
Chenje
Hello everyone, I noticed that the drawers in my KALLAX shelving unit don’t fit properly – they seem crooked and don’t open and close smoothly. I assembled it following the instructions exactly and didn’t skip any steps. So I’m wondering: what could cause KALLAX drawers to sit unevenly? Could it be due to the assembly, manufacturing defects, or the adjustment of the drawer slides? Maybe someone here has had a similar issue and can offer advice on how to fix it. Thanks in advance!
Jeanbar
24 Jul 2021 12:15
Roberta schrieb:
Sometimes the drawer just doesn’t slide in properly, and then it looks crooked.
That’s a good point. The KALLAX drawers can easily be inserted crookedly if the runners are not properly engaged. Many people forget to slide the runner over the guide pin, which results in insufficient support.
Additionally, if the shelf board sags, the entire structure can tilt slightly, affecting the drawers. In this case, placing shims under the legs or leveling the shelving unit helps.
V
vinpau
25 Jul 2021 08:07
Hello, I had the same problem before, and it was because the floor in the room was not completely level. I simply placed small felt pads under the shelf to make it stand straight, and since then the drawers fit perfectly! The KALLAX is sturdy, but even slight unevenness can affect its alignment. 🙂 So, check if the shelf is really standing completely level!
Surela
25 Jul 2021 08:46
vinpau schrieb:
The KALLAX is sturdy, but even slight unevenness can affect the alignment.
Exactly! Additional note: If the back panel is not completely flush or has warped due to moisture, this can also cause distortion. In that case, the edges of the drawer runners will no longer be at right angles. I would therefore also be interested to know whether the back panel was installed correctly and without any tilt.
Chenje
25 Jul 2021 09:18
vinpau schrieb:
I simply placed small felt pads under the shelf to level it, and since then the drawers fit perfectly! 🙂
Thanks for the tip, I will check the floor again, although I thought it was even.
Surela schrieb:
I’m also interested in whether the back panel was installed correctly and without any tilt.
I have checked the back panel several times; it seems to be properly seated, but small shifts can easily be overlooked. I will re-examine the tension of the back panel.
Yesterday, I checked all the screws on the drawer slides again and made slight adjustments, but the fit of the bottom drawer is still not perfect. So, back to it. Thanks to all of you, very helpful!
Elijah42
26 Jul 2021 07:53
If the drawers are misaligned, a small adjustment by gently aligning the metal slides with a screwdriver often helps. Tightening the screws on the opposite side can also be effective. Sometimes it is just a slight tilting that causes the annoying misalignment. Check this with a spirit level on the drawer front.
