ᐅ Are KALLAX doors sticking after temperature changes – is that normal?
Created on: 10 Feb 2021 14:07
Lumopar
Lumopar
10 Feb 2021 14:07
Hello everyone, I have a question regarding my IKEA KALLAX shelf doors. I have noticed that after a temperature change, especially when it gets colder, the doors start to stick. They no longer open or close as smoothly as before. I suspect that the material might be expanding or contracting due to the temperature change, which causes this behavior. However, I am not sure if this is normal for KALLAX doors or if it could be a design flaw or even a material issue.
Has anyone had similar experiences? And are there any tips on how to effectively address this problem without causing permanent damage to the doors? I would appreciate knowledgeable responses, preferably with explanations on why this behavior might occur with furniture of this type.
Juan31
10 Feb 2021 15:23
The observed issue with sticking KALLAX doors after temperature changes is technically understandable and is well-known for furniture made from wood-based materials.
Wood-based materials and similar products respond to changes in temperature and humidity by expanding or contracting. KALLAX consists of particleboard with a melamine resin coating, which is less flexible than solid wood but still absorbs and releases moisture to some extent.
This can cause the door surfaces to warp, leading to sticking. This is usually not a permanent design flaw. However, the doors should be adjustable (e.g., with screws on the hinges) to allow for play adjustment.
My advice: Check the hinges for adjustment options and make the necessary corrections. If humidity fluctuates significantly, climate control in the room or the use of a humidifier can help reduce material expansion.
SUDAN
10 Feb 2021 16:45
Juan31 schrieb:
Wood-based panels and similar materials react to changes in temperature and humidity by expanding or contracting.
This is exactly the key point! I would like to provide a brief guide on how to better understand and possibly resolve such issues:
1. Identify the cause: As Juan31 mentioned, wood-based panels warp due to moisture and temperature fluctuations. This can still be noticeable with laminate finishes.
2. Check doors: Inspect whether hinges and fittings are loose or misaligned. Screws can usually be tightened or adjusted.
3. Adjustment: Many KALLAX doors allow the hinges to be slightly adjusted—either vertically or horizontally. This often effectively resolves any sticking.
4. Consider the environment: Fluctuations tend to be greater in unheated or damp rooms. Using a dehumidifier or maintaining a consistent room temperature can help.
5. Long-term: If the problem persists, door replacement through IKEA may be considered, especially if there is a material defect.
Conclusion: The material’s physical properties are crucial here; this behavior is normal, although inconvenient. Technically, it can be minimized by adjustment and improved indoor climate control.
V
vin_leo
11 Feb 2021 09:17
Lumopar schrieb:
KALLAX doors stick after a temperature change, especially when it gets colder. What can be done?
Yes, I’m familiar with that—my KALLAX has a bit of an identity crisis with temperature fluctuations 😅. Jokes aside: this thermal behavior is quite normal. Slightly loosening the hinges, adjusting them, and definitely avoiding forcing the door open or closed will help, otherwise it only gets worse.
A small tip: in winter, try opening and closing the door gently and more often, like a little exercise for the furniture—this keeps the mechanisms and materials more flexible 😉.
If the sticking becomes worse, sometimes gently sanding the door edge where it meets the frame can help—but be careful and do only minimal sanding to preserve the design. Also, always avoid damaging any resin surface finishes! 🙂
Lidan56
11 Feb 2021 10:55
This behavior is normal for wood-based materials. Doors may stick due to expansion and contraction. Tightening or adjusting the screws on the hinges usually helps. Keep temperature and humidity stable, if possible.
BOSULE
12 Feb 2021 08:33
Juan31 schrieb:
If the humidity fluctuates significantly, air conditioning in the room or using a humidifier can help
That is a very good point. Additionally, I recommend ensuring that the doors are properly installed and that there is no warping of the furniture itself. The KALLAX unit, in particular, is relatively delicate in design and reacts more sensitively to environmental changes. Regular checks of the doors, especially after the heating season, can help detect problems early.
If the door is permanently warped, sanding it afterward often provides only limited relief and can damage the surface finish. If the furniture is covered by a warranty, replacement through IKEA is usually straightforward.
